AlanS1 Posted December 3, 2014 Share Posted December 3, 2014 The speedo drive hole is used as the filling point only as it is far easier to get to on my car. As i did strip and clean, fit new bearings,seals and a new Quaife on my gearbox i know that it was totally empty on mine. I then measured out the 2.4ltrs. If i was just topping up then you would still have to remove the fill/level plug to ensure that you do not over fill. However i would still top up via my speedo drive hole. Doing it this way i also know straight away when i have enough oil in as there is not anything like a pipe etc blocking the fill/level hole. Like mentioned everyone to their own. Link to comment Share on other sites More sharing options...
@ndy Posted December 3, 2014 Share Posted December 3, 2014 Is the speedo drive at the same height as the fill plug then? It should take 2.4L IIRC. ^^This^^ The speedo drive hole is used as the filling point only as it is far easier to get to on my car. As i did strip and clean, fit new bearings,seals and a new Quaife on my gearbox i know that it was totally empty on mine. I then measured out the 2.4ltrs. If i was just topping up then you would still have to remove the fill/level plug to ensure that you do not over fill. However i would still top up via my speedo drive hole. Doing it this way i also know straight away when i have enough oil in as there is not anything like a pipe etc blocking the fill/level hole. Like mentioned everyone to their own. Sounds practical.... Will give this a go next time Link to comment Share on other sites More sharing options...
Alex B Posted December 6, 2014 Author Share Posted December 6, 2014 Had yesterday off work, it give myself a fighting chance of being done in time for thunder in the park . Start the morning off around 10:30ish with bleeding the coolant. The seloc guide wasn't overly helpful, so a quick couple of phone calls with the oracle (Gav) and I was clear on how to do it. Oil cooler mounting, this was the first attempt and it sat to high Quick rethink and it now fits comfortably Took the car for a quick couple of laps round the block, seems to drive fine. Air filter back on. Rear clam back on The bay Running a lot healthier now Link to comment Share on other sites More sharing options...
@ndy Posted December 6, 2014 Share Posted December 6, 2014 1 week to go Alex..... Looking good Link to comment Share on other sites More sharing options...
DeanB Posted December 6, 2014 Share Posted December 6, 2014 fantastic Alex. well done mate. Link to comment Share on other sites More sharing options...
Meister Posted December 6, 2014 Share Posted December 6, 2014 Good work Alex...you've put some effort into that! Link to comment Share on other sites More sharing options...
russelld Posted December 6, 2014 Share Posted December 6, 2014 Well done Alex, keep this one topped up TAGL :-) Link to comment Share on other sites More sharing options...
Alex B Posted December 6, 2014 Author Share Posted December 6, 2014 Well put the last few bits back on today and went for a little drive. Interior, any excuse to show of the beautiful yet somewhat dirty seats. Boot/bonnet on, pain in the ass to line up. Just a few finishing touches left now, one of these is sorting the cam timing out. Link to comment Share on other sites More sharing options...
Martin R Posted December 6, 2014 Share Posted December 6, 2014 Alex, good work. I still have the timing gear if you need it? Link to comment Share on other sites More sharing options...
Alex B Posted December 6, 2014 Author Share Posted December 6, 2014 Alex, good work. I still have the timing gear if you need it? Thanks Martin, I have a set of dti's now, and have borrowed Alan's frames, hoping to get it done tomorrow however depends if I get called out to work or not. Link to comment Share on other sites More sharing options...
John FISH Curtis Posted December 7, 2014 Share Posted December 7, 2014 Well done Alex, should see you next weekend. Link to comment Share on other sites More sharing options...
Alex B Posted December 7, 2014 Author Share Posted December 7, 2014 Cam timing done this afternoon much better just need to find a decent map to use until remapping. Link to comment Share on other sites More sharing options...
Martin R Posted December 7, 2014 Share Posted December 7, 2014 Cam timing done this afternoon much better just need to find a decent map to use until remapping. Alex, can you get in touch with the last owner and get his map or get it off Emerald if it was done there? Link to comment Share on other sites More sharing options...
Austintaff Posted December 7, 2014 Share Posted December 7, 2014 Alex, Didn't know it needed full replacement! Really impressed with what you have done! I've just about sussed out how to use a sponge but spanners!!!! Fingers crossed all is well for next weekend? Link to comment Share on other sites More sharing options...
Alex B Posted December 7, 2014 Author Share Posted December 7, 2014 Alex, can you get in touch with the last owner and get his map or get it off Emerald if it was done there?Unfortunately not Martin.Previously ran off standard ecu with VVC it's now running my solid cams. It shouldn't be too hard to sort, I was playing around with them yesterday as it power delivery was very hesitant in each map. First thing to try is my Northampton motorsport map. Link to comment Share on other sites More sharing options...
