KurtB Posted November 29, 2014 Share Posted November 29, 2014 It's looking good Alex. Keep the faith, despite your run of bad luck, it'll be worth it in the end :-) Link to comment Share on other sites More sharing options...
Alex B Posted November 29, 2014 Author Share Posted November 29, 2014 Turn it over a couple of times by hand with the plugs out. Just to make sure nothing is amiss. Good luck turns over freely with plugs in however i need to replace them so will do it without just to double check. Link to comment Share on other sites More sharing options...
Dr H Posted November 29, 2014 Share Posted November 29, 2014 Good work Alex. Soon be up and running Link to comment Share on other sites More sharing options...
Alex B Posted December 3, 2014 Author Share Posted December 3, 2014 Tuesdays antics. Ht leads swapped over Driveshafts in Tidied cables etc up. Oil and gear oil went in Emerald hooked back up. Battery was pretty flat due to leaving it off charge... Ooops. So shall see if it fires up tonight. Oh yeah and I broke the speedo drive you remove to fill the gearbox....double ooops Link to comment Share on other sites More sharing options...
Alex B Posted December 3, 2014 Author Share Posted December 3, 2014 So tonight, I replaced the broken speedo drive. Tried starting it. No fuel coming through Ran through the fuel system wiring. Found out I had incorrectly connected a live up. Corrected it and this happened.... No cat, back box or air filter Ok so there's still along way to go. Link to comment Share on other sites More sharing options...
scatty Posted December 3, 2014 Share Posted December 3, 2014 Slowly slowly catchy monkey. Whatever the fcuk that means... Keep going mate, soon be there... Link to comment Share on other sites More sharing options...
Alex B Posted December 3, 2014 Author Share Posted December 3, 2014 Slowly slowly catchy monkey. Whatever the fcuk that means... Keep going mate, soon be there... See above scat man! Link to comment Share on other sites More sharing options...
scatty Posted December 3, 2014 Share Posted December 3, 2014 Boom..... Ready for donny??? Link to comment Share on other sites More sharing options...
Alex B Posted December 3, 2014 Author Share Posted December 3, 2014 Boom..... Ready for donny??? Will be by the end of Saturday!!! Link to comment Share on other sites More sharing options...
Martin R Posted December 3, 2014 Share Posted December 3, 2014 Alex, good work. What speedo drive? I have always removed #11 on here to fill the gearbox. Its handily labeled as fill plug http://www.deroure.com/diagrams.asp?TBL=1319&MAK=1&MDL=13&SMA=0&SMO=0&ST=&SC=0 Fill till it just dribbles out on flat ground and job done. Link to comment Share on other sites More sharing options...
Alex B Posted December 3, 2014 Author Share Posted December 3, 2014 Alex, good work. What speedo drive? I have always removed #11 on here to fill the gearbox. Its handily labeled as fill plug http://www.deroure.com/diagrams.asp?TBL=1319&MAK=1&MDL=13&SMA=0&SMO=0&ST=&SC=0 Fill till it just dribbles out on flat ground and job done. The one that isn't used. Link to comment Share on other sites More sharing options...
@ndy Posted December 3, 2014 Share Posted December 3, 2014 Looking good Alex.... Nice to see DIY builds / upgrades As Martin mentioned, Filling the gearbox is done via the fill plug until it dribbles out, I use a short piece of garden hose with a funnel pushed in to the top, Takes a while to fill thou Link to comment Share on other sites More sharing options...
AlanS1 Posted December 3, 2014 Share Posted December 3, 2014 Its a great feeling when it fires up and all runs after so much hard work. I remove the speedo to fill the box. Its easier on mine as i have the ally removable panel. Everyone to there own. Link to comment Share on other sites More sharing options...
Alex B Posted December 3, 2014 Author Share Posted December 3, 2014 Looking good Alex.... Nice to see DIY builds / upgrades As Martin mentioned, Filling the gearbox is done via the fill plug until it dribbles out, I use a short piece of garden hose with a funnel pushed in to the top, Takes a while to fill thou Thanks Andy!Look forward to reading yours. If you is the unused speedo drive it's easier to get to. Link to comment Share on other sites More sharing options...
Martin R Posted December 3, 2014 Share Posted December 3, 2014 Is the speedo drive at the same height as the fill plug then? It should take 2.4L IIRC. Link to comment Share on other sites More sharing options...
