Alex B Posted January 10, 2015 Author Share Posted January 10, 2015 Alex try them without the helpers. If you set your ride height to where you want and the springs are not loose at full droop ( wheel jacked off the floor ). No need for helpers and it is a lot less faffing. My rears springs are 550lbs and I do not need helper springs / it could be different with the S1 though ? Cheers for the pointers Russ. I've spent this afternoon playing with ride heights and In order to avoid loose springs at full droop I've had to use helpers front and back. I will however be ordering some EP lowering brackets which will allow me to remove the helpers. Ride height is now reset at 105rear 95front More pics in the day light. Link to comment Share on other sites More sharing options...
russelld Posted January 10, 2015 Share Posted January 10, 2015 Blood hell that's low ! Mine is 120 front 125 rear, any lower with an S2 and the front clam wont clear speed bumps :-( Link to comment Share on other sites More sharing options...
AlanS1 Posted January 10, 2015 Share Posted January 10, 2015 I now have mine set to 106 front and 116 rear. Any lower and the wish bones go past the horizontal point. It may also differ depending on where you measure from? Link to comment Share on other sites More sharing options...
Alex B Posted January 10, 2015 Author Share Posted January 10, 2015 Blood hell that's low ! Mine is 120 front 125 rear, any lower with an S2 and the front clam wont clear speed bumps :-(Haven't tried speed bumps yet.I believe mine are set at the same height as Jody's car. I now have mine set to 106 front and 116 rear. Any lower and the wish bones go past the horizontal point. It may also differ depending on where you measure from? Will be redone in a week or so once they've settled some more and my new brackets have arrived. Link to comment Share on other sites More sharing options...
Alex B Posted January 16, 2015 Author Share Posted January 16, 2015 Well the cars been mapped. 170.7bhp 141.8lb ft torque Pleased with the result, however had loads of idling issues which have been just about sorted however it seems to kangaroo a lot on low throttle since. Link to comment Share on other sites More sharing options...
@ndy Posted January 16, 2015 Share Posted January 16, 2015 That's a great result Alex, I bet that goes well..... Cant help on the Kangaroo issue, Was it present during the mapping ? Link to comment Share on other sites More sharing options...
Alex B Posted January 16, 2015 Author Share Posted January 16, 2015 That's a great result Alex, I bet that goes well..... Cant help on the Kangaroo issue, Was it present during the mapping ? Not that I know of its come from trying to sort the idling out. Will ring Troy at Northampton motorsport Up and see what he suggests. When accelerating it going like shit of a shovel! Link to comment Share on other sites More sharing options...
DeanB Posted January 16, 2015 Share Posted January 16, 2015 170 brake?!? that's immense! I bet you're well chuffed. That's fifty whole horses more than I have. Link to comment Share on other sites More sharing options...
AlanS1 Posted January 16, 2015 Share Posted January 16, 2015 Good figures Alex, but what is the mid range like? How long did it take Troy? I am sure he will not what to do to help the kangaroo effect you are getting. I meant "know" what to do. (I phone) Link to comment Share on other sites More sharing options...
Alex B Posted January 16, 2015 Author Share Posted January 16, 2015 Good figures Alex, but what is the mid range like? How long did it take Troy? I am sure he will not what to do to help the kangaroo effect you are getting. I meant "know" what to do. (I phone) Very good torque curve and power is smooth all the way. Will post graphs shortly. Link to comment Share on other sites More sharing options...
Alex B Posted January 17, 2015 Author Share Posted January 17, 2015 Link to comment Share on other sites More sharing options...
AlanS1 Posted January 17, 2015 Share Posted January 17, 2015 Good graph Alex. So the only thing different on this engine compared to your old engine is the head has been ported? Link to comment Share on other sites More sharing options...
DeanB Posted January 17, 2015 Share Posted January 17, 2015 Great curves. There can't be many k series cars on plenums with more power can there? Really good torque low down and max power not too high. I am envious! Link to comment Share on other sites More sharing options...
Alex B Posted January 17, 2015 Author Share Posted January 17, 2015 Good graph Alex. So the only thing different on this engine compared to your old engine is the head has been ported? Head porting, 218cc injectors (cream) Great curves. There can't be many k series cars on plenums with more power can there? Really good torque low down and max power not too high. I am envious! Not sure on that Dean, there might be a few running nearer the 180bhp mark, I am however running fairly mild cams. Also spoke to Troy regarding the kangarooing, he's told me what to try n if Im still not happy bring it down n he will sort it. Link to comment Share on other sites More sharing options...
Martin R Posted January 17, 2015 Share Posted January 17, 2015 Alex, that looks lovely. I look forward to a ride in it Link to comment Share on other sites More sharing options...
