jonnyfox Posted September 8, 2018 Author Posted September 8, 2018 Thanks Paul. Looking forward to seeing the 340R buddy.
jonnyfox Posted October 5, 2018 Author Posted October 5, 2018 Well a quick update, no images. Ran it in over the back end of summer. Took it to Gav for an oil change, found two very minor leaks from the gearbox and oil pump. May need a new rear off side bearing, not completely sure but on the whole a few more miles wouldn't hurt. Honestly it drives beautifully, it's so bloody lovely but I fear I will be selling it next year once I consider it perfect. I won't go mad with the price but I don't want to be the guy who never drives it, nor do I want to be the guy that clocks up the miles. So a bit of a catch 22 I guess. I'm going to leave it to someone else to make that choice. Exciting though because I'll get to find another Lotus and enjoy that too. I will end this thread a some point with some really classy images as I want all the memories fully intact.
Daveb99 Posted October 5, 2018 Posted October 5, 2018 6 hours ago, jonnyfox said: Well a quick update, no images. Ran it in over the back end of summer. Took it to Gav for an oil change, found two very minor leaks from the gearbox and oil pump. May need a new rear off side bearing, not completely sure but on the whole a few more miles wouldn't hurt. Honestly it drives beautifully, it's so bloody lovely but I fear I will be selling it next year once I consider it perfect. I won't go mad with the price but I don't want to be the guy who never drives it, nor do I want to be the guy that clocks up the miles. So a bit of a catch 22 I guess. I'm going to leave it to someone else to make that choice. Exciting though because I'll get to find another Lotus and enjoy that too. I will end this thread a some point with some really classy images as I want all the memories fully intact. Jonny, you CAN'T sell it after the work you’ve put in. There can’t be another S1 Exige as nice and well restored as yours out there, why not keep it and simply do say 500-1000 miles a year in it - happy medium? You get to enjoy all your hard work but don’t ruin it or like you say, clock up the miles...
kieranexige Posted October 6, 2018 Posted October 6, 2018 19 hours ago, Daveb99 said: Jonny, you CAN'T sell it after the work you’ve put in. There can’t be another S1 Exige as nice and well restored as yours out there, why not keep it and simply do say 500-1000 miles a year in it - happy medium? You get to enjoy all your hard work but don’t ruin it or like you say, clock up the miles... Or for that mileage... Sell it scatty.
jonnyfox Posted October 7, 2018 Author Posted October 7, 2018 I know I know thanks Dave and really love it but I'm really caught in two minds.
Dr H Posted October 8, 2018 Posted October 8, 2018 This seems to be quite a common theme with people who spend ages restoring / building cars! Maybe the fun and interest is all in the building and that's what you love doing. The OH thinks I'll be the same with the Stratos and once it's built I'll not want to use it. A couple of fellow LB builders have sold very soon after completion. Either way someone will get an amazing car Jonny!
jonnyfox Posted October 27, 2018 Author Posted October 27, 2018 I just can't make my mind up, honestly I do love my Exige. I'm just a little scared to drive the bloody thing, add the miles and well, make it not so pretty I had a couple of days to give it a good clean before hibernation, it really is one shiny car inside and out. I took the opportunity to finally clean the underside of the chassis, this was always a job I wanted to do last but enough was enough. I even stuck on new jacking stickers, yep properly went to town lol. I also finally fitted the alternator cooling hose which only required a couple of cable ties and a little bit of metal work fabrication of an aluminium bracket. Quite straightforward really. Oh and I also bought a dehumidifier As it stands I'll have it shipped off to Gav early new year to rectify the oil leaks, both minor. Fairly sure since nipping up the bolts on the oil pump that one is sorted. The gearbox is but a tiny seal which can be done on the hoist. Thanks to 'Dredge" btw for letting me nose around his beauty while at Gav's to see how and where the cooling pipe is fitted. Sleepy time.....
The Cakes Posted October 27, 2018 Posted October 27, 2018 No problem Les! Haha! Car looks great as ever. Do you need to sell this to fund the next? If not just tuck it away and let it appreciate. I’m 99% sure you’d regret it. Maybe keep it for a year and see how you feel, far too early in your relationship to make such decisions
Dr H Posted October 29, 2018 Posted October 29, 2018 I'm with you on the dilemma. When you've spent so much time and effort making it perfect, it will only get 'imperfect' as you use it
jonnyfox Posted November 7, 2018 Author Posted November 7, 2018 One question I keep being asked is how much I have spent on the car? I really don't know, I kind of lost track but if you know your apples.... Bonnet hinge and shims anodised Bonnet latch striker and spring assembly zinc coated AC removed Front shear panel anodised Chassis Aluminium cleaned underside, front & rear Crash structure cleaned Horn refurbished Heater box refurbed, fixings zinc coated, motor refurbished New custom powder coated aluminium battery mounting with AC cooling bypass and washer bottle mount New washer bottle and pump EP New washer nozzles EP and OE caps anodised New wipe blade EP New Odyssey battery New electrical cut out EP with custom mounting New OE heater hose Refurb resister assembly Front hub carriers cleaned and polished, new hub assembly EP, bearings and circlips SL New tow post assembly EP New driver spot lights and fixing assembly EP New silicon radiator hoses/pipes EP New cooling fans EP and fixings ES New Pro Alloy triple pass radiator Full suspension refresh including: Wishbones, ARB, ball joint carriers front & rear, steering arms, rear hubs, lower rear wishbone brackets to chassis, upper damper mounts shot blast, zinc coated, POR 15 clear applied, 2 coats. New ball joints and bushes SL New drop links SL Suspension refresh kit including all shims SL New Ohlin 36mm 2 way dampers 325/450 New ARB mounts EP New rear tow links and shields EP Steering rack serviced at Titan including new gaiters New track rod ends SL Front latch mechanism shot blast, zinc coated and mounting power coated New OE brake dust shields New brake master cylinder SL New clutch master cylinder SL New OE rubber connecting hose New braided hoses front & rear SL New AP front brake discs and bells SL New EP rear discs with refurbed bells (anodised) New rear brake lines New OE front and rear brake callipers New Pagid pads front and rear SL Dot 4 brake fluid New OE handbrake secondary Passenger bulkhead stripped and cleaned Stays stripped and painted with POR 15 black. Caps added. Rear subframe removed, stripped and galvanised Spacers to chassis shot blast, zinc coated and POR 15 Silver applied New OE longerons Fuel tank removed and replaced with new larger Pro Alloy tank New fuel pump SL New silicon fuel tank filler and breather hose Fuel filler assembly shot blast, zinc coated and POR 15 clear applied New fuel filter and HPE mounting New braided fuel hose, unions and rail fixing New filler assembly stainless ring and gasket Aluminium shear panel stripped and anodised Aluminium cooling pipes polished, mounts zinc coated PRT kit/grey EP New header tank EP New silicon cooling pipe/hose EP MAP/BARO vacuum mount shot blast, zinc coated and power coated Solenoid valves vacuum refurbed, new silicon hose New vehicle speed sensor EP New OE throttle position sensor New aluminium mounts to rear hub Engine gearbox mounts shot blast, zinc coated and powder coated Door spring plates and hinge shims shot blast, zinc coated and (plates only) powder coated Alternator mount shot blast and zinc coated Alloys shot blast and powder coated New Yokoham AD08’s New aluminium wheel bolts HPE New aluminium boot floor New OE heatshield boot floor New OE heatshield above cat New aluminium undertray and OE NACA ducts New aluminium diffuser New diffuser spacers EP New OE throttle pedal assembly Brake & clutch pedal anodised New aluminium engine divider All interior removed, inside cleaned throughout Footwell vents blocked with anodised aluminium panels New FEV gas electrically operated extinguisher 2 nozzles inside cabin and two in the engine bay Seat mounts stripped, shot blast and powder coated. Driver rails cleaned regreased and wet sprayed Interior trimmed at Allon Whites include: Seats, upper dash panels, dash cowling, door trim including handle pull trim, sill trim pads, roof lining and steering wheel including new horn and badge. New quick release plastic trim fasteners. Carpet under seats Bulkhead trim cleaned Stereo and speakers removed, anodised aluminium blanking plates fitted OE dash stereo blanking cover fitted New adonised aluminium floors panel bonded over old with Sikafkex New OE mats Foot rest, window winders, foot divider and foot rest stripped and anodised New OE rear tunnel cover Body painted gear lever and hand brake covers New OE hand brake handle New OE gear knob and shrink sleeve New OE cigarette lighter and assembly Painted dash, dash inserts including trinket trays and steering column shroud AC & Recirc switches replaced with OE switch blanks 4 point harness washed and cleaned, one new buckle fitted New windscreen and rubber bead Windscreen surround painted Door striker pin shot blast and zinc coated and new OE plastic surround Interior roof mounts stripped and POR15 black applied Refurbished gearbox HPE New OE wheel arch liners SJS and weather strip Head light bracket shot blast and zinc coated New headlights and seals EP Front and rear grills powder coated – front clam inc side and rear clam fog/reverse Airbox back plate shot blast and powder coated Ceramic coated manifold, flexy and decat. Exhaust stripped, cleaned, repacked and wet sprayed with high temp paint New V band, blue mounts and refurbished fixing shot blast and zinc coated Full VHPD engine strip & rebuild Reface valve seats Hone con rod small ends Soda Blasting Silver high temp engine paint Mahle motorsport Main bearings Mahle motorsport big-end bearings Thrust washers Westwood ductile Liner Set (OE) Sump baffled Uprated main bearing ladder Forged Wiseco Piston Set ARP con rod bolt set Throttle body/ injector clean & service Gasket set (conversion kit) Gasket set (head set) Oil pump Water pump Head bolt set Timing belt Timing belt manual tensioner Alternator Starter motor Kent Cams vernier cam pulley set Kent Cams VS51 valve spring set REC757 S/S Inlet valve VVC 31.5mm Paul Ivey REC758 S/S Exhaust valve VVC 27.3mm Paul Ivey New OE oil cooler, new unions and braided hose AP clutch kit New clutch slave with strengthen kit EP New clutch arm with reinforce wielding EP New engine steady arm, both parts EP New OE hydromount assembly Refurbished upper engine to chassis mount, shot blast, zinc coated and powder coated New OE breather rail and silicon piping New OE driveshafts Xylan Coated rocker cover New alternator cooling hose and EP heat shield kit New Nimbus single skin manifold/bulkhead heatshield Refurbished OE bulkhead heatshield covered with Agriemach aluminised heat barrier Airbox cleaned inside and out New OE hose intake duct to airbox Refurbished OE air filters (aka witches hat) Refurbished and clean door seals with 3M VHB tape applied Door hinges cleaned, new caps New outer window seals ES New OE door access caps above latch Refurbished cleaned inner seals New OE Meta immobilizer Refurbished OE Meta keys New OE front clam harness New OE engine harness New JSR rear clam harness Main harness (most) sleeving replaced for new, front, rear and inside New OE indicator/flash arm steering column Refurbished headlight lens covers All bodywork painted original Chrome Orange paint code B25 Roof, engine cover and bonnet grills POR 15 black applied Roof/engine cover hinge painted New OE Lotus nose badge New OE indicator lenses New OE side indicator/repeaters New OE Lotus & Exige decals Refurbished front number plate mount, shot blast & powder coated New OE labelling fuel, jacking, films etc. New OE rear clam brake, indictor, EP fog, reverse light and number plate light Refurbished reflectors New OE engine cover latch mechanism and cover Refurbished striker shot blast and zinc coated New OE stone chip protection rear clam (black) New rear clam rubber strip to sill New OE vehicle manual & service book
Phil S1 Posted November 7, 2018 Posted November 7, 2018 Wow! I'm not going to try and add that lot up Jonny, that's one exceptionally long till receipt What price can anyone put on the best S1 Exige ever built?!!!
kieranexige Posted November 7, 2018 Posted November 7, 2018 Vhpd full rebuild... Enough said . Proper Job Jonny, when can I drop the 190 off?
The Cakes Posted November 7, 2018 Posted November 7, 2018 Doesn’t even bear thinking about what the labour charge would have added to the above if you hadn’t done most of it! Jesus wept!! I’m guessing £30/40k for that list above!?!?! Worth every penny
Dr H Posted November 7, 2018 Posted November 7, 2018 C'mon Jonny you must have an idea - you just don't want to admit it . I'm in a similar situation with the LB build but I've kept a VERY detailed spreadsheet! Having said that, I'm never going to admit what I've spent on it .
