Honda Engine Elise Build
danwebster
  • Replies 329
Dan
I just discovered this thread and am impressed with what you have done. I am doing a very similar project to put a k20 into my 111S - target is at least 350 BHP as it is going to be my track day car so I am going for a rotrex
It shares a garage with a Ferrari 430, so 350 should make it a lot faster than the Ferrari !!!!!
One question is how did you connect your fuel pipes to the nylon outlet stubs on the top of the fuel pump holder ? It looks like you didn't use the standard lines. I want to use braided lines as I am using the in tank pump as a lifter pump into a fuel swirl pot as the supercharged engine will probably melt if I get any fuel starvation.
Thanks Simon
Simon
I'll be very very interested to hear how it compares to the 430. My Honda is running close to 380hp and weighs just over 800kg,
The fitting for the pump is something like this:
http://www.ebay.co.uk/itm/AN-6-6AN-JIC-AN-06-Quick-Connect-5-16-Female-Fuel-Line-Rail-Adapter-BLACK-/170764095506?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item27c2555012
Not sure what size as this is available in 3/8 and 5/16 hard line.
Leigh
Dr H
Thanks for the ebay link. Sure this will help others who are uprating fuel lines .......... this is what forums like this are really good for.
Simon
As the s1 pump outlets are both the same size, which coincides perfectly with the bore size of my fuel hose, I simply pushed them on and used hose clamps on them.
  • 3 months later...
Been tinkering with the part throttle mapping a bit and introduced a few pops and bangs just for laughs...
It was spitting massive flames the other day so I was hoping to catch those, hence the camera angle. The exhaust exits from the undertray.
  • 5 months later...
I've been rather busy lately but didn't realise that I neglected to update my thread with my new engine biggrin.png
A while back I built another engine for the car, it's basically standard with the exception of some 87mm forged omega pistons.
I started out by prepping a block, I actually used a type S block for various reasons. To use a type s block though you need to drill and tap the oil squirter holes as they are not present.
2ADF3B1A-947C-4327-87EC-40EFDF18D359_zps
Then I had a complete bottom end assembly balanced and assembled ready to go in.
86581B40-AAFD-4ED3-9E34-5F6896F98475_zps
Bottom end built.
3610045D-C40E-4DB0-B629-FE49E98DBC67_zps
As the bores are now 1mm bigger it was necessary to chamber the head to suit. This is done on a cnc machine and then finished by my own fair hands.
722A073C-EE7B-4121-B9BF-5BE183FC0F43_zps
With the head assembled its time to prep the rest of there bits and turn it into an engine.
09542D6D-979D-41AE-A268-9C9CED973196_zps
Big ends and mains plastiguaged and clearances set perfectly.
19E2E651-9220-45FC-A9ED-F0CD8EA1F9DF_zps
Getting there....
6AE85134-45EE-40A6-A723-B0BEA570022B_zps
63E96D28-18BC-4E41-AB6F-250F47919AF7_zps
Set those tappets!
48C1CCB4-3B51-4D4F-9F15-8E6A6B49E1DD_zps
Then it was a quick swap job, one out....
028C047C-B569-48A8-86C7-AE9D980E6C33_zps
5B2F221C-0981-42D6-9D62-EBF44CDBC451_zps
And a new one in...
E114FD4C-2892-4D23-9DEF-BD13DD899625_zps
Also took a couple of pics on my way home from the workshop.....just because smile.png
4B07F259-64C4-454B-A136-3A64E07743DD_zps
F8937207-BDD6-4371-896A-2ADB427D9620_zps
Fitted a gauge pod a while back to motor oil temp, pressure and lambda.
210B743F-59CD-4B33-8836-E89056195944_zps
Where did you get the shiny gold stuff on the bulkhead from?
Has it done the job as expected? Any increase in noise or heat in the cabin?
Alan
I got it from ATL, it's almost unbelievably good at what it does, as it's heat reflective it doesn't even get hot on the engine bay side let alone the cabin.
There is no sound deadening in the car so it's extremely noisy.
