J J Lester Posted May 11, 2021 Share Posted May 11, 2021 Greetings, I’m in love with the Exige S3 but to my horror I’ve found I don’t fit. At 6.3” I’m not exactly freakishly tall, but the problem is my very long legs hitting the steering wheel and gearstick. Headroom seems fine, probably even with a helmet on. I’m reading about removing sliders, using steering spacers, Tillett buckets etc. Anything to get as low and far back as possible. Has anyone here done this? Any help greatly appreciated. Best, JJ Link to comment Share on other sites More sharing options...
Daveb99 Posted May 11, 2021 Share Posted May 11, 2021 Simple. Buy an Evora and save yourself some cash too. This one looks lovely... https://www.pistonheads.com/buy/listing/11649475 Link to comment Share on other sites More sharing options...
winthattt Posted May 13, 2021 Share Posted May 13, 2021 Same problem with my son, 6ft 4inch and does not fit, legs touch the wheel. Gave up trying to get him to fit. His best option was a race bag seat (expanded foam) in the well. Head restraints were then I problem and I could not drive it. Link to comment Share on other sites More sharing options...
tobyg Posted May 15, 2021 Share Posted May 15, 2021 I'm 6.2", although I fitted fine I've made some improvements... I changed the seats to Corbeau LE Pro's on standard runners with a custom lower cushion so the seat now sits lower. I've also raised the steering column with some 5mm washers, which gives about 20mm rise at the wheel. This will give you much needed leg room. I also have a removable wheel which is closer to the driver by about 20mm, this helps with leg room too. I never have the need to take the wheel off to get in or out. Link to comment Share on other sites More sharing options...
Adtmits Posted May 16, 2021 Share Posted May 16, 2021 Im 6ft 1" and just at the limit, so can definitely see the issue for those who are taller. Link to comment Share on other sites More sharing options...
Stik Posted May 17, 2021 Share Posted May 17, 2021 i think it must depend on proportions a lot too, i'm 6'4 and i've never had any trouble in my vx220 or any of the lotuses i've owned. It's cozy, and yeah my knees hit the steering column, but i've adopted a kind of john wayne style of driving. my biggest problem is if i'm at the front of a queue at the traffic lights, i can't see the damned things Link to comment Share on other sites More sharing options...
Lunner Posted May 17, 2021 Share Posted May 17, 2021 I am 6'4", and just fit in with half inch clear room above my head. Have a removable steering wheel, which means i can JUST get my knees under it, if i wear shoes with thin soles. My biggest issue is working out how to gain a bit more headroom so i can fit in there wth a lid on for track days. If anyone has any bright ideas i'm all ears Link to comment Share on other sites More sharing options...
Stik Posted May 19, 2021 Share Posted May 19, 2021 i've got that problem too, i've tried my motorbike helmet but there's no a chance i can wear it with the roof on. Are open-face race helmets any slimmer? didn't really want to buy one if it still wasn't going to fit Link to comment Share on other sites More sharing options...
PJT Posted May 19, 2021 Share Posted May 19, 2021 Have you tried one of those WW2 pilot helmets made out of Leather? I also have an issue seeing the traffic lights. Often hang my head out of the side window to see. I find it tight too, but do not have my seat all the way back in fact. I can not get on with the carbon fibre seats as I think they are more reclined. My head bangs on the top roll bar thingy. Link to comment Share on other sites More sharing options...
Lunner Posted May 20, 2021 Share Posted May 20, 2021 Need to find a manufacturer that makes quite thin helmets...... Toying with the idea of spacing the steering wheel closer to me, and then just slouching in the seat. Don't want to shell out for a tillet seat, and then find i still have the same problem Link to comment Share on other sites More sharing options...
Stik Posted May 20, 2021 Share Posted May 20, 2021 i've never tried a lotus with anything other than the standard factory seats, perhaps once covid is more over i need to have a sit in other people's Link to comment Share on other sites More sharing options...
Alpinetracks Posted May 21, 2021 Share Posted May 21, 2021 On 17/05/2021 at 13:01, Stik said: i think it must depend on proportions a lot too, i'm 6'4 and i've never had any trouble in my vx220 or any of the lotuses i've owned. It's cozy, and yeah my knees hit the steering column, but i've adopted a kind of john wayne style of driving. my biggest problem is if i'm at the front of a queue at the traffic lights, i can't see the damned things Agree it's down to proportions. I'm 6'2 and have never had difficulty with any of the tubs or seats. But came here to really say the traffic light thing is an easy thing to sort! If you're right at the traffic light line and can't see directly, you just need to look in the reflection of your front wing on the top. Perfect visibility to always see the lights whatever the weather, and see when they change without having to contort yourself! Worked in my VX years back too - it's like when they were designed they knew what they were doing Link to comment Share on other sites More sharing options...
PJT Posted May 21, 2021 Share Posted May 21, 2021 I will try that. Thanks. I remember when I had my S2000, I used to like driving only looking at the reflections on the big long bonnet (only for short spell mind) Link to comment Share on other sites More sharing options...
Stik Posted May 22, 2021 Share Posted May 22, 2021 On 21/05/2021 at 10:06, Gormski said: Agree it's down to proportions. I'm 6'2 and have never had difficulty with any of the tubs or seats. But came here to really say the traffic light thing is an easy thing to sort! If you're right at the traffic light line and can't see directly, you just need to look in the reflection of your front wing on the top. Perfect visibility to always see the lights whatever the weather, and see when they change without having to contort yourself! Worked in my VX years back too - it's like when they were designed they knew what they were doing You are implying I keep my car shiny enough to see reflections Link to comment Share on other sites More sharing options...
scatty Posted June 6, 2021 Share Posted June 6, 2021 I’m 6ft 4 with giraffe like legs.. removable wheel with 20mm spacer should be fine for you... A helmet on the other hand, I’m with all the other lanky streaks of piss.. I can fit with one. But it kind of hits the roof.. I tried an open face one but no joy... Link to comment Share on other sites More sharing options...
