jonnyfox
  • Replies 581
  • 2 weeks later...
I remember someone telling me, there is something so satisfying about using new parts with clean new fixings on a rebuild, its very true. Cooling (PRT), clutchtastic and starter motor :)
20171020_165806
2017-10-22_04-34-21
20171022_162426
20171022_162414
2017-10-22_10-39-35
Using new shiny bits is great - it's just the cost that hurts!
Looking great.
Wiggled the manifold up and on. Had to remove the oil filter and bottom engine mount.  A strap helped tilt the engine to give more room. Finished by fitting the alternator heat shield and popping the oil filter and engine mount back on.
20171024_211208
20171024_223958
20171024_224102
2017-10-24_10-59-27
You gotta love a bit of Zircotec coating :tup:
Try not to bleed on it. Took bloomin' ages for it to burn off when I managed to bleed on mine!
55 minutes ago, Rob999 said:
Can you stop interrupting Dan from working on my car JF! :P
:lol: shouldn't be too much longer, one more trip.
3 things...
Little snag this evening, the boot floor could be a better fit so I'll have to get a new one drawn up and made pronto.  I was hoping to fit the heat shield and the rest of the exhaust tonight. I've also decided to fit a standard engine mount and ditch the EP one.  The OE mount that came off the car wins the award for best most rusted part so I'll either buy new or find a good second hand one. So a trip to see Rocky in the morning and a new hydromount. Lastly I'm going back to the original steering wheel so that's off to Allon White's to be trimmed.
20171025_204040
20171025_094712
20171025_094746
I sanded and painted the stays again the other night, smoother than ever :)
20171026_155749
20171026_155741
Popped over to UK Lotus Centre to see Rocky today. Picked up an engine mount in much better condition then my own, that's now gone for shot blasting. While I was there I had a rather emotional reunion....
20171026_103734
20171026_103714
I stripped it and sold the parts after the engine let go. Track Group bought the chassis off me but it's found its way back to Halesowen.  I didn't ask Chris although the chassis is straight.
Reused my old door seals which apart from the adhesive were perfect. So I used some VHB tape to stick them back onto the car. Cleaned the filthy hinges, used the old shims which were Zinc coated a while ago, popped in new like for like fixings and went all S2 with the spring plates (which I'd also shot blast, Zinc & powder coated) ) by adding the plastic follower. Will pop the door cards on and maybe the stickers tomorrow.
20171101_172041
20171101_172012
20171101_171925
20171101_171946
20171101_213619
20171101_213649
20171101_213258
20171101_213340
20171101_172137
20171101_172217
