JonS Posted November 10, 2013 Posted November 10, 2013 On my way home from Bedford last weekend I pulled into a car park to take this photo. I couldn't resist! Happy 100,000 to the Bug! It's been quite a journey!
stockhome Posted November 10, 2013 Posted November 10, 2013 Congratulations Jon mine has not even done half that.How much has it done since the rebuild?
MilesH Posted November 10, 2013 Posted November 10, 2013 Congrats, many more fun filled miles to come I'm sure! As long as the fun outweighs the turmoil these little cars brings us (and more than not they do!) then it makes it worth it
JonS Posted November 10, 2013 Author Posted November 10, 2013 Cheers both. The smiles have only got bigger since Dave Andrew worked his magic. The car is phenominal now from its previous incarnation, and pulls like a train! Shame it's now the long dark nights as I had some great roofless commutes this Summer, both to and from work!
Martin R Posted November 10, 2013 Posted November 10, 2013 That is one of the many good things about them IMO. They are like Triggers broom. Im sure you will have many many more miles and smiles from it
JonS Posted November 10, 2013 Author Posted November 10, 2013 They are like Triggers broom. lol nice analogy Martin! It's very true as well.. especially with the number of brake pads and discs I'm getting through of late!
DeanB Posted November 11, 2013 Posted November 11, 2013 Nice one Jon. Looking at that picture 43 miles to a gallon of fuel ain't bad either! IIRC DVA didn't rebuild the bottom end, is that right? You don't hear of many bottom end failures on the Ks though do you?
Alex B Posted November 11, 2013 Posted November 11, 2013 Good going jon, certainly doesn't look like it's done 100k!
JonS Posted November 11, 2013 Author Posted November 11, 2013 Nice one Jon. Looking at that picture 43 miles to a gallon of fuel ain't bad either! IIRC DVA didn't rebuild the bottom end, is that right? You don't hear of many bottom end failures on the Ks though do you? DVA did a full rebuild in the end. Took the whole car to him and left it with him for a week. He doesn't usually take whole cars but allowed me to do it. I had to wait for warmer weather too! 43mpg isn't bad - I've had better! I usually get about 37ish mpg on long drives. This one was a bit slower due to the fact I had no rear breaks!
fentuz Posted November 11, 2013 Posted November 11, 2013 IIRC DVA didn't rebuild the bottom end, is that right? You don't hear of many bottom end failures on the Ks though do you? Dependants where is your rev limiters. If you don't exceed 6K rpm, it last for a while. If you go towards/above 7K rpm, you are pushing the std piston a little far hence why piston 160 are recommended when running over 6.8rpm. Tim had a failure with his engine after pushing at rev limit (6950rpm) what I believe was a STD S2 bottom end with a DVA head and 633 cams.
Martin R Posted November 11, 2013 Posted November 11, 2013 Bill, he had also done dozens if not in the hundred trackdays
fentuz Posted November 12, 2013 Posted November 12, 2013 You're quite right Martin. I meant the bottom end usually fails when you play at high Rpm for a while (ie trackday/ sprinting). If it is only a road car, few people go above 5000 rpm for a long time. Mine is quite old and seems to hold together but my rev limiter is set at 6200rpm
