Big Power For The Lego Brick!
MrSimba
  • Replies 123
Fantastic, torque on tap.
That is definitely supercar slayer territory. That's one hell of a car you have now Simon.
Yep... got up this morning & heard the rain lashing down before I'd even looked out of the window and though just the day to be finding the biting point on that new paddle clutch with 400ft lb waiting to go behind you!!!
Better pack my ballet shoes! :D
Nice one Simon can't wait to see it
Think you'll probably have heard it a few times before you see it!!! ;)
That's going to be nuts!! Chris Randles racing Europa uses the same engine and he pretty much leaves it in 4th due to all the torque!! Excellent result, look forward to seeing and hearing it. Top job.
The car is actually very different to drive to how I imagined, Far more smoother in the delivery, no on/off hesitations or stutters that the OE ECU likes to throw at you! very linear, actually a much safer more predictable car then my stage 4 was, the stage 4 had LOTS of torque2500-3500rpm (which could be fun in the wet...) then it started to fall away, the Garrett starts to make torque at 3000rpm and it not until 3800rpm that it matches the stage 4 (which is by now losing torque) then from 4000rpm to 6300rpm it holds up to 384ft lb and no less than 300ft lb so massive torque where you need it smile.png
The bhp again is under the stage 4 until 3800rpm then BOOM! its just 'Defcon1' all the way to the 7300rpm limiter biggrin.png
In short its more linear, more refined, much much more powerful car, but with the a far safer delivery, I had had possible plans for multiple maps, Defcon1, wet, low torque ect but after feeling just how refined the map Chris has developed multimaps are not required, this map really is just fine smile.png
Have to say though any gear, once your at 3000rpm if you do ask it to boost the car just squats and goes...! its warp speed, both I and Dave Hardwick have driven it this afternoon and both of us can't really see why you'd ever need any more power in a road car, basically its just on the limits in the dry of having more power than traction, any more and you'd be scared to go WOT, Chris actually when I got there this morning had road tested it after he finished mapping late last night and he'd backed the power off as he was worried it would start eating gearboxs! hence the 363/384!
Think the power to weight ration is now 437bhp / ton which is 100bhp/ton MORE than a V10 Gallardo! so as said ain't exactly slow!!! wink.png
Anyway the graphs.....
The 'dip' at 5300rpm is seen on all tuners maps, chris scratched his head and could not map it out so looked at CS, Klassen, ect and they all have it so think is a characteristic of the cam profile?
This graph is my stage 4 on Chris's rollers overlaid with the Garrett map for comparison smile.png
Very impressive!
437 bhp/tonne is just right ;) My car is 350hp and 800kg so 437 bhp/tonne
Mind you, you do seem to have a tad more torque.......................eek.gif
The description of the car now sounds amazing. Did you have to do anything extra on the braking front?
Thanks Bis :)
The car has AP 4 pots up front, std bremb rears, braided lines & ATE 'superblue' fluid & CL5+ pads all round - it stops as well as it goes!!!
Can't wait to see it Simon.
I'll listen out for a low-flying missile going through Boldmere.
We need another 'Horse & Jockey' night to catch up!
Agreed.
Name the night - we need to make sure Mr Fox can be there too...haven't seen him in ages.
Agreed.
That's not Simon Fox is it? Had a dolphin grey VX in the day?
