Badger02 Posted December 9, 2023 Author Share Posted December 9, 2023 New ARB bushes have arrived Quote Link to comment Share on other sites More sharing options...
Badger02 Posted December 9, 2023 Author Share Posted December 9, 2023 Took the heater assembly out this morning. Bit of a pain as space it tight. Found it easier to remove the fan from the rad cover 1st. Then lower the rad into the bottom space, rotate 90 degrees, then easy to lift out. Bit rusty and needs a small repair but otherwise not too bad Getting the fan of the shaft I ended up having to use a punch and lump hammer as it was stuck on solid. Currently fan cover is coated in paint stripper then I'll remove the paint and then put it in a bucket of rust remover. Quote Link to comment Share on other sites More sharing options...
Badger02 Posted December 10, 2023 Author Share Posted December 10, 2023 So, they've gone in a bucket of water mixed with Deox C, will see the result in a day or two Quote Link to comment Share on other sites More sharing options...
Badger02 Posted December 10, 2023 Author Share Posted December 10, 2023 A common problem on S1's is that the bolts that go into the captive nuts at the bottom rear of the clam sieze and then when you apply force the captive nuts detach from the sill meaning they then spin, which is what's happened on mine. So i dremeled the bolt heads of, knocked the remaining part of the bolts and captive nuts into the sill. To fish them out from the sill I removed the coin tray (stupid amount of sealant used) which reveals a hole, then with a bendy magnet wire I could get them out. Quote Link to comment Share on other sites More sharing options...
Badger02 Posted December 12, 2023 Author Share Posted December 12, 2023 After 2 days in Deox C that's looking a lot better. Couple of rust spots remaining so back in the bucket it's gone. Couple of repairs needed (the stud bolt on the bottom has snapped) before I'll apply Kurust and then paint it. Quote Link to comment Share on other sites More sharing options...
martenr1975 Posted December 12, 2023 Share Posted December 12, 2023 3 hours ago, Badger02 said: After 2 days in Deox C that's looking a lot better. Couple of rust spots remaining so back in the bucket it's gone. Couple of repairs needed (the stud bolt on the bottom has snapped) before I'll apply Kurust and then paint it. Wow! What a transformation. I have always found Bilt Hamber stuff great. Just looked at Deox and interesting to see it's available in a gel too, if parts to be treated aren't easily dunked in a bucket 👍 1 Quote Link to comment Share on other sites More sharing options...
Badger02 Posted December 12, 2023 Author Share Posted December 12, 2023 39 minutes ago, martenr1975 said: Wow! What a transformation. I have always found Bilt Hamber stuff great. Just looked at Deox and interesting to see it's available in a gel too, if parts to be treated aren't easily dunked in a bucket 👍 Yes, 1st time I've used Deox C and very impressed with it Quote Link to comment Share on other sites More sharing options...
Badger02 Posted December 13, 2023 Author Share Posted December 13, 2023 ARB with new bushes refitted and Kurust doing its thing on the heater fan cover Quote Link to comment Share on other sites More sharing options...
Badger02 Posted December 14, 2023 Author Share Posted December 14, 2023 A lick of hammerite on the fan cover and motor. Getting there Quote Link to comment Share on other sites More sharing options...
Badger02 Posted December 16, 2023 Author Share Posted December 16, 2023 New and old heater rad Quote Link to comment Share on other sites More sharing options...
Badger02 Posted December 16, 2023 Author Share Posted December 16, 2023 Heater box which is rather flimsy I have to say given a lick of paint Quote Link to comment Share on other sites More sharing options...
Badger02 Posted December 16, 2023 Author Share Posted December 16, 2023 Did a test with some different types of rivnuts (for the clam shell), am concerned that the amount of force required to get them to bite will damage the fibreglass, so have ordered some heavy duty velcro tape to try instead Quote Link to comment Share on other sites More sharing options...
Badger02 Posted December 16, 2023 Author Share Posted December 16, 2023 On reassembling the heater box with the new rad, the holes for the rivets clashed slightly with the rad. I ummed and ahhed for a bit, thought I'd try some long cable ties to hold it together, but then the extra thickness of the ties meant the box wouldn't fit in the space Lotus left for it (which has almost no clearence). In the end I elongated the holes a bit to ensure the rivets missed the rad. Quote Link to comment Share on other sites More sharing options...
Badger02 Posted December 17, 2023 Author Share Posted December 17, 2023 Gave the heater and battery bay a deep clean and painted the bottom. The before and after Quote Link to comment Share on other sites More sharing options...
Badger02 Posted December 17, 2023 Author Share Posted December 17, 2023 Gave the coin trays a respray Quote Link to comment Share on other sites More sharing options...
