Badger02 Posted December 2, 2023 Author Share Posted December 2, 2023 New driving light brackets and light protectors installed plus new tow mount. Next up is to remove and hopefully be able to refurb the anti roll bar and also rivet old fan to new rad Quote Link to comment Share on other sites More sharing options...
Badger02 Posted December 2, 2023 Author Share Posted December 2, 2023 Welcome to version 2, each light is marked with a TOP on the glass (didn't know that) so of it all came, and after a bit of head scratching now correct. Quote Link to comment Share on other sites More sharing options...
Badger02 Posted December 2, 2023 Author Share Posted December 2, 2023 And old fan riveted to new rad Quote Link to comment Share on other sites More sharing options...
Guido Posted December 2, 2023 Share Posted December 2, 2023 I find this kind of thing fascinating. I just wish I had the skills to do something like this myself. I’m an expert at taking things apart but bloody awful at putting things back together again!!! Quote Link to comment Share on other sites More sharing options...
Badger02 Posted December 3, 2023 Author Share Posted December 3, 2023 10 hours ago, Guido said: I find this kind of thing fascinating. I just wish I had the skills to do something like this myself. I’m an expert at taking things apart but bloody awful at putting things back together again!!! The most important thing is attitude. I've not done most of things I'm doing now before, but I'm willing to give it a go and TRY. Sometimes I get things wrong and have to take a step back, but hey ho , no big deal. Quote Link to comment Share on other sites More sharing options...
Guido Posted December 3, 2023 Share Posted December 3, 2023 Very true!! My biggest fear is trying something and then having to call an expert in to fix what I have done!! If I have a step by step guide I’m happy (YouTube can be very helpful) but going in ‘blind’ would frighten me to death. Quote Link to comment Share on other sites More sharing options...
Badger02 Posted December 4, 2023 Author Share Posted December 4, 2023 Rad and cover reassembled with SS fixings Quote Link to comment Share on other sites More sharing options...
Badger02 Posted December 4, 2023 Author Share Posted December 4, 2023 Great access to the allen bolts that secure the ARB ! Quote Link to comment Share on other sites More sharing options...
Lithopsian Posted December 4, 2023 Share Posted December 4, 2023 Well-known issue. Bottom one is essentially not accessible with the wishbone on. The upper one can be accessed either with a long allen key or a (very sturdy!) cut-down one. They are steel into an aluminium housing (with the rubber bushes) and will be well welded in by now. You'll need a high quality allen bit and some beef behind it. If you come at them from the rear you can get penetrating fluid where it will do some good. Some people have replaced the capheads with hex bolts which lets you use a regular spanner, but you'll have to guess the torque if you go this route. The torque isn't too critical as you should use a thread sealant and that should stop anything vibrating loose. Just make sure you don't strip the threads in the aluminium block. Quote Link to comment Share on other sites More sharing options...
Badger02 Posted December 4, 2023 Author Share Posted December 4, 2023 Yes, I've just ordered a set of extra long hex allen bolts with sockets on the ends. I'm hoping that removing the damper and then jacking up the wishbone will give me the necessary access. Quote Link to comment Share on other sites More sharing options...
Lithopsian Posted December 5, 2023 Share Posted December 5, 2023 I suspect you won't get a long one on the bottom bolt. I seem to remember trying the same thing and the wishbone just wouldn't move far enough. Still, worth a try if you don't fancy dismantling the whole suspension just yet. What you can do is get a stubby hex bit in the caphead and try turning it with a ring spanner. Fiddly, especially trying to break it loose the first time, and you have to get it well seated and keep it there, but it is worth a try. Unless you have some fancy tools, you won't be able to get a torque wrench on to put it back together. Quote Link to comment Share on other sites More sharing options...
Badger02 Posted December 6, 2023 Author Share Posted December 6, 2023 ARB is out and no drama. Now to derust, bit of hammerite, new bushes, reinstall 😀 Needed to buy some long allen sockets to get access to the bolts Quote Link to comment Share on other sites More sharing options...
Badger02 Posted December 7, 2023 Author Share Posted December 7, 2023 Cleaned up ok I think after a bit of work with my dremel grinder Quote Link to comment Share on other sites More sharing options...
Badger02 Posted December 7, 2023 Author Share Posted December 7, 2023 ARB bushes are buggered, so ordered new ones Quote Link to comment Share on other sites More sharing options...
Badger02 Posted December 7, 2023 Author Share Posted December 7, 2023 All that glitters is gold Quote Link to comment Share on other sites More sharing options...
