AlanS1 Posted July 22, 2014 Share Posted July 22, 2014 I could always lend you a hammer? I also have one with a very long handle so that you wouldn't have to bend down too much to pick it up if you prefer? Link to comment Share on other sites More sharing options...
scatty Posted July 22, 2014 Share Posted July 22, 2014 Alan, even I know that's a croquet stick.... Link to comment Share on other sites More sharing options...
AlanS1 Posted July 22, 2014 Share Posted July 22, 2014 Not with a steel end and 14Ilb stamped on the end! Link to comment Share on other sites More sharing options...
Alex B Posted July 22, 2014 Author Share Posted July 22, 2014 Welcome to my world. I presume you have fitted the Emerald at the same time? The new ones will allow you to keep the IACV. Try putting your foot down on the accelerator slightly when trying to start. If it then runs the IACV probably wants setting up in the Emerald. Also make sure the immobiliser is disabled in the programme. Good luck.Yes emerald installed think the cold start on my map Is at fault, however if it isn't it'll be timing is out too much. Link to comment Share on other sites More sharing options...
Martin R Posted July 22, 2014 Share Posted July 22, 2014 Yes emerald installed think the cold start on my map Is at fault, however if it isn't it'll be timing is out too much. Have a look at the cranking enrichment settings then. Although if it was that i would have thought it would have started with a bit of throttle? I printed off a fair bit of the Emerald instructions and put them in a folder. I will bring them to Chatsworth if you like? I find it a lot easier to follow than on disc. Link to comment Share on other sites More sharing options...
Alex B Posted July 22, 2014 Author Share Posted July 22, 2014 It coughed and splutter a lot. Didn't wanna try too many time a cause it was nearly 10pm Link to comment Share on other sites More sharing options...
John FISH Curtis Posted July 23, 2014 Share Posted July 23, 2014 Update Alex!!?? Link to comment Share on other sites More sharing options...
Alex B Posted July 23, 2014 Author Share Posted July 23, 2014 It cranks fine, coughs n splutters but doesn't fire up. Link to comment Share on other sites More sharing options...
Alex B Posted July 24, 2014 Author Share Posted July 24, 2014 It lives!!!!! Link to comment Share on other sites More sharing options...
Phil S1 Posted July 24, 2014 Share Posted July 24, 2014 Woohoo....there's hope yet! Link to comment Share on other sites More sharing options...
Martin R Posted July 24, 2014 Share Posted July 24, 2014 Well, thank f##k for that. Well done Link to comment Share on other sites More sharing options...
Alex B Posted July 24, 2014 Author Share Posted July 24, 2014 It has however lead me to another issue. Link to comment Share on other sites More sharing options...
scatty Posted July 24, 2014 Share Posted July 24, 2014 Oh god, what now..... Link to comment Share on other sites More sharing options...
Alex B Posted July 24, 2014 Author Share Posted July 24, 2014 need to machine a sensor down in order for the emerald to work. Link to comment Share on other sites More sharing options...
dobbo Posted July 24, 2014 Share Posted July 24, 2014 Nail file ? If you need files, grinding wheel, pillar drill etc, let me know !! Link to comment Share on other sites More sharing options...
