Badger02 Posted March 22 Author Share Posted March 22 Thanks for the feedback and the heads up. I bought the dual layer 4.45mm thick sheet so should be ok Quote Link to comment Share on other sites More sharing options...
Badger02 Posted March 23 Author Share Posted March 23 Done Quote Link to comment Share on other sites More sharing options...
Badger02 Posted March 26 Author Share Posted March 26 Apart from the tie rod to fit, I'd say the passenger side rear is done with wishbones derusted, painted and lacquered, new bushes and ball joints, caliper painted and new brake flexi and clips, hub cleaned and painted, plus transmission seal replaced Quote Link to comment Share on other sites More sharing options...
Badger02 Posted March 30 Author Share Posted March 30 Fitted some new rubber and SS spacer washers today. Glued them in place as you definitely don't want these moving as you're putting the clams back on Quote Link to comment Share on other sites More sharing options...
Badger02 Posted March 30 Author Share Posted March 30 Installed a new long side driveshaft seal also today. Hopefully this one won't leak like the original one did which explains all the crud Quote Link to comment Share on other sites More sharing options...
Badger02 Posted March 31 Author Share Posted March 31 Drivers side rear is done. Quote Link to comment Share on other sites More sharing options...
Badger02 Posted March 31 Author Share Posted March 31 A tip for you, when installing the long driveshaft, make sure the accelerator cable is routed between the engine and the driveshaft. Otherwise you'll end up doing what I had to do which was disconnect the cable at the throttle body, re route it, then reconnect it. Quote Link to comment Share on other sites More sharing options...
Badger02 Posted March 31 Author Share Posted March 31 Bloke from https://mgroversolutions.com/ to do the head gasket, cambelt change, install new exhaust flexi section and we'll do new coolant at the same time is booked to come to my place for the 8th April. Then I can start thinking to put the rear clam back on. Quote Link to comment Share on other sites More sharing options...
Badger02 Posted April 3 Author Share Posted April 3 Couple of more jobs completed. Vinyl applied to the rear wheel arch sills and new heatshield around the accelerator cable with a new P clip as well Quote Link to comment Share on other sites More sharing options...
Badger02 Posted April 4 Author Share Posted April 4 Derusted the roll bar supports and gave them a coat of hammerite Quote Link to comment Share on other sites More sharing options...
Badger02 Posted April 4 Author Share Posted April 4 Cleaned up, painted and lacquered the speaker pods. The before and after Quote Link to comment Share on other sites More sharing options...
Badger02 Posted April 5 Author Share Posted April 5 New heatshield is in Quote Link to comment Share on other sites More sharing options...
Dave-hp Posted April 5 Share Posted April 5 Looking good. Its interesting to see all the various inner parts, most of us dont get to pull apart, for now..... But at some point, we may do...... Quote Link to comment Share on other sites More sharing options...
Badger02 Posted April 5 Author Share Posted April 5 1 hour ago, Dave-hp said: Looking good. Its interesting to see all the various inner parts, most of us dont get to pull apart, for now..... But at some point, we may do...... Thanks, you should go for it - it's not that daunting. On Monday, the K series expert mobile mechanic is coming to my house to change the cambelt and the head gasket, so I'll be seeing parts of my engine I've not seen before Quote Link to comment Share on other sites More sharing options...
Badger02 Posted April 6 Author Share Posted April 6 Refitted the headlights that I restored a few months ago complete with new foam seals Quote Link to comment Share on other sites More sharing options...
