Badger02 Posted February 14, 2023 Share Posted February 14, 2023 I've been mulling over getting a car lift for sometime, but have limited headroom of approx 2300mm. For easier maintenance, but also to get my 4 toys in garage (photo attached shows my 3 toys but not my VW camper van) Had more or less resigned myself to a 4 post due to the headroom restriction, but was concerned about how much space it would take up (I planned to install it in the middle bay). Yesterday I spoke with a nice guy from twinbusch who said: Only get a 4 post if you have plenty of space, otherwise get a 2 post. I said your shortest 2 post is 2320mm and I only have 2300mm. His reply, no problem we can take 100mm of the top of each post for an extra £100 but you will lose 100mm of lifting height. He quoted me more or less £2700 for this model including vat, delivery, install and chopping 100mm of the top and could do it all by end of Feb. I'd get some plastic sheeting to loosely put over the bottom car in case of any oil drips Am sorely tempted now to press the button, but before I do was wondering if anyone had good or bad experiences with car lifts and elise cars they'd like to share. Thanks Link to comment Share on other sites More sharing options...
Phil Hutchins Posted February 14, 2023 Share Posted February 14, 2023 You said you’d got “approx 2300mm” headroom: are you sure that you couldn’t squeeze another 20mm in by eg: cutting into the plasterboard ceiling? It seems a bit draconian to have a full 100mm cut off and loose that headroom below. Also if it were me I’d put it at one side rather in the centre to still keep a double-bay. Link to comment Share on other sites More sharing options...
DeanB Posted February 14, 2023 Share Posted February 14, 2023 Gav at Unit 4 uses a two post lift. It works fine provided you put the arms in the right place. I presume even with your slightly restricted ceiling you can still fit a car underneath? I agree with Phil about putting it on the end bay. Oh, and I'm not jealous at all. Oh no. I don't want a triple garage with a lift. And two Lotuses. And bifold doors. 😅 Link to comment Share on other sites More sharing options...
Badger02 Posted February 14, 2023 Author Share Posted February 14, 2023 Found this other lift that is only 2024mm height and a reasonable price too. I'm in 2 minds whether to put the lift in one of the outer bays or middle bay, still need to work it all out in my head and a scrap of paper. An elise is roughly 1150mm high with roof on. The centre beam that goes sideways left to right in my garage is 2100mm floor to underside so approx 200mm lower than 2 elise with their roofs on, excluding any clearance between them. The advantage of a 2 post instead of a 4 post is that with a 4 post you need more height for 2 cars because the top cars tyres are sitting on the ramps, with a 2 post you need less height because the lifting arms are actually under the car (hope that makes sense) If it doesn't work with roofs on there are 2 options 1. Take both roofs off 2. The top car take roof of plus windows down and have the sideways garage beam sit between the windscreen top bar and the rear screen top bar Anyway, this is for me to ponder and work out. I really wanted to see what people's experiences of 2 post or 4 post lifts were and if they had any good or bad experiences with any particular companies. Thanks Link to comment Share on other sites More sharing options...
Badger02 Posted February 14, 2023 Author Share Posted February 14, 2023 Just going through the datasheet of that lift, and it shows 100mm from floor to top of lifting pad which seems OK to get under a stock elise. Worse case put 4 low rise ramps on floor to lift car slightly up Link to comment Share on other sites More sharing options...
DeanB Posted February 14, 2023 Share Posted February 14, 2023 You will need to think it through very carefully if you will need the garage roof beam to pass inbetween the roll bar cover and windscreen. I imagine where the posts are sited will be critical. Link to comment Share on other sites More sharing options...
Badger02 Posted February 14, 2023 Author Share Posted February 14, 2023 2 hours ago, DeanB said: You will need to think it through very carefully if you will need the garage roof beam to pass inbetween the roll bar cover and windscreen. I imagine where the posts are sited will be critical. Yes, good points. Would position an elise in the right place so that the roof beam goes in between the 2 bars and then position the lift to suit Link to comment Share on other sites More sharing options...
Badger02 Posted February 14, 2023 Author Share Posted February 14, 2023 Also found this lift which they say is portable, not sure exactly how as I imagine the posts are pretty heavy. Will give them a call to get more details. Link to comment Share on other sites More sharing options...
MG4Lotus Posted February 15, 2023 Share Posted February 15, 2023 Just a thought: When the top car is being lifted won't the wheels hang a bit lower than when the car is on the ground and the suspension is compressed by the weight of the car. Link to comment Share on other sites More sharing options...
MG4Lotus Posted February 15, 2023 Share Posted February 15, 2023 Can you dig a pit to give extra space if required? Link to comment Share on other sites More sharing options...
Badger02 Posted February 15, 2023 Author Share Posted February 15, 2023 4 hours ago, MG4Lotus said: Just a thought: When the top car is being lifted won't the wheels hang a bit lower than when the car is on the ground and the suspension is compressed by the weight of the car. Yes, you are probably right Link to comment Share on other sites More sharing options...
Badger02 Posted February 15, 2023 Author Share Posted February 15, 2023 4 hours ago, MG4Lotus said: Can you dig a pit to give extra space if required? Yes, though that would be a bit of a last resort, same last resort as having to sell a toy, yikes Link to comment Share on other sites More sharing options...
Broadside Posted February 17, 2023 Share Posted February 17, 2023 Just be aware that an Elise is the 'wrong way round' compared to a normal FWD car in terms of weight distribution. I always put them on the lift the opposite way round, ie with the engine over the short arms. It's also a good idea to use a ratchet strap to secure the front end of the car to the arms if your doing anything fairly physical on the car as they do tend be a bit back end heavy. Just as a an extra safety measure. Link to comment Share on other sites More sharing options...
Badger02 Posted February 18, 2023 Author Share Posted February 18, 2023 19 hours ago, Broadside said: Just be aware that an Elise is the 'wrong way round' compared to a normal FWD car in terms of weight distribution. I always put them on the lift the opposite way round, ie with the engine over the short arms. It's also a good idea to use a ratchet strap to secure the front end of the car to the arms if your doing anything fairly physical on the car as they do tend be a bit back end heavy. Just as a an extra safety measure. Thanks for the advice Link to comment Share on other sites More sharing options...
