Martin R Posted February 28, 2013 Share Posted February 28, 2013 The dip is a bit funny. Is it caused by the cams? I doubt you will notice it with all that poke mind Link to comment Share on other sites More sharing options...
DJWilma Posted March 1, 2013 Author Share Posted March 1, 2013 Think your right still has 300lbft of torque when it dips. Could be cams but more likely be a restriction in the inlet or exhaust. Just need it to rev past 7000rpm for gearing more than anything Link to comment Share on other sites More sharing options...
DJWilma Posted April 14, 2013 Author Share Posted April 14, 2013 Well things are going a bit slower than I want but few snags on the way The speedo is now working it has a stand alone pulse converter The temp gauge now works, thanks arno and rotivator for the help its run off the dta and is now reading the correct temp Afr gauge has been added to the centre consol But the oil filter adaptor is leaking as its porous so needs to be replaced We think the lack of revs is the head, the t series head isnt a wonderful design esp on the exhaust so I have purchased a ported head, some mechanical lifters and uprated springs and will run some piper 285 cams or a custom billet and try to rev to 8k Car now needs to be shipped off to the body shop to get finished......summer is coming Link to comment Share on other sites More sharing options...
DJWilma Posted April 20, 2013 Author Share Posted April 20, 2013 So 382bhp and 371lbft just doesnt cut it, actually 6250rpm doesnt. C6 gearbox is just too short so need more revs, may loose a little bottom end but hoping to gain 1500rpm top end So, i made some enquiries and came up with a plan of a ported and polished head with Mechanical Lifters, uprated single springs and some billet cams. So i managed to get a head, its been ported but i only paid £200 for it, add to this the mechanical lifters and the springs (same as a k series) i purchased and all i needed was the billet cams Spoke with Grant at gb-ent and he said £800 plus VAT, Piper said 1200 so i thought long and hard and in the end have sent some cams for a re-grind to Piper 285M via Drew at roverdose. Not ideal but i havent even driven the bloody thing yet !! In fact the only elise i have driven is a 340R, to the end of friends road and back, and a S2 of Junks, where i reversed 20 yards. So the head malarky, will happen after the summer, car is on its way back as we speak from JDM Dyno in Cumbria so i can enjoy it as its nearly a year since purchase. Pics of Ported Head, David Bailey eat your heart out Exhaust Inlet Oh and the seats i have are blue and material, as the leather seats were sold, so i bought this drunk off of ebay........ They have a stamp saying 2002 so assume close enough for now Plan is to get it re-sprayed and on the road within the next 4 weeks........ Link to comment Share on other sites More sharing options...
DJWilma Posted April 22, 2013 Author Share Posted April 22, 2013 The car arrived home a day early, i was just trying to check in to a flight to Norway (which i missed), when the nice man called to say he was 30 mins away. Long story short my brother met the man and car is now at friends Lock Up awaiting being stripped and re-sprayed.......Starlight Black as per the original car Engine in, only issue is the throttle cable hits the bonnet, so may need to adjust one of them....... Nice big Dump Valve Ickle Bit tight for the turbo but a ahem "Chimney" style heat shield, turbo blanket and baulkhead has been given the heat shiel treatment. Should help, undertray has a massive naca duct in it underneath and engine bay has a 4" in line fan to move air around when stopped or hot... Charge Cooler, looks like a custom fit.....however its a Fiat Seicento std radiator, which is twin pass, with a modded end tank to take the 19mm tube to the charge cooler Rear looks fairly std, as it has the original 3" Lotus ends :cool Vibratechnics engine mount, and a few things in where the wheel arch should go so may need a little move around :beat Inside the car we added the AFR gauge, the centre consol can do it but easier to look at the MTX, passengers knee may hit it so will remove the wifes right leg if this happens (y) Front Clam with triple pass Pro-Alloy rad with 2 pull radiators.....charge cooler also has fans on back side for added cooling AP 4 pot brakes look tiny against the 308MM discs, from a Vectra re-drilled to suit Elise Hub, all under std 111S wheels Little, bad video, have explained to mate never to rev and switch off the engine again......or i kill him Sounds and footage is terrible so will get a better one later. Its has a resonance through the longer pipe, so blocking this quietens the exhaust.....just in case its too loud i can bung a bung or orifice into it Link to comment Share on other sites More sharing options...
Martin R Posted April 22, 2013 Share Posted April 22, 2013 Nice work, is your mate old enough to have owned an old car with carbs? That used to be the trick to get extra fuel in the carbs before switching off IIRC. It used to help them start on cold winter mornings, that and fiddling with the choke Link to comment Share on other sites More sharing options...
M@r]{ Posted April 22, 2013 Share Posted April 22, 2013 Looks and sounds good Link to comment Share on other sites More sharing options...
DJWilma Posted April 22, 2013 Author Share Posted April 22, 2013 Nice work, is your mate old enough to have owned an old car with carbs? That used to be the trick to get extra fuel in the carbs before switching off IIRC. It used to help them start on cold winter mornings, that and fiddling with the choke Yep he is a Classic Mini man......he gets one warning Link to comment Share on other sites More sharing options...
DJWilma Posted June 15, 2013 Author Share Posted June 15, 2013 Well things slowed to a halt, promotion at work lots of travel and so on have meant the cars been on the back burner but finally getting things done The throttle linkage needed changing as the m series inlet was fouling the rear clam, now fits underneath Wiring is a mess so having this tidied up and the addition of a seperate fuel pump relay for the motor sport pump But the main issue is the front clam. Bodge it and scarper painted it a lovely blue which had gone crazy. Tried to sand it off and it goes too mooch and clogs the paper as they just painted onto the original paint without sanding. Only way to remove is with a scraper which is time consuming Hoping to have the car complete by end of june Link to comment Share on other sites More sharing options...
jonnyfox Posted June 16, 2013 Share Posted June 16, 2013 Me too both on the paint and of June although the paint was my fault......but I have employees who were bored lol. Still getting there ;-) Link to comment Share on other sites More sharing options...
DJWilma Posted July 5, 2013 Author Share Posted July 5, 2013 Well this is becoming annoying. Been so busy with work the car hasnt moved on much. So today I left early and finally did some stuff The fuels pumps have been wired in on seperate relays now, but on running it up it now has a fuel leak on the old regulator, so have to change the fuel rail grrr But final got the rear inner arches on And the front n/s. Am I right with the fusebox and relays ? Link to comment Share on other sites More sharing options...
DJWilma Posted July 18, 2013 Author Share Posted July 18, 2013 Failure.......this is the word of the day but in the grand scheme of things, and after some soul searching and being told not to be grumpy "its only a car" i have come to terms with the MOT failure today ! It didnt fail on much, i couldnt find the drivers side mirror, the aim on one of the lights is low but worst of all the steering rack is buggered. So basically the car looks like this now It needs to be sprayed but my insurance company are threatening to cancel the policy so it had to be done this week. Here it is on the MOT Bay at K-tec racing, passed the emissions no problems, but it ran out of electricity and has sprung an oil leak.....so off with the rear clam again ! But before all that went Pete Tong we took this video, not be driving as Scott cant use a camera its 20 seconds of your life you wont get back, but even i am thinking this doesnt exist sometimes ! www.youtube.com/watch?v=ohsScfjDDK4&feature=youtube_gdata_player Link to comment Share on other sites More sharing options...
Alex B Posted July 18, 2013 Share Posted July 18, 2013 what made the insurance threaten to cancel your policy? Link to comment Share on other sites More sharing options...
DJWilma Posted July 24, 2013 Author Share Posted July 24, 2013 Insurance issue is lack of MOT, VIC test and V5 in my name after 60 days of insurance and non of these documents to present they are a little "worried" Well i know the reason the rack felt ok but was horrible to drive / failed the mot The casing was cracked on the passenger side close to the pinion..... Luckily i ordered a new rack from the ever quick elise parts, went for the quick rack as it sounded cool so its fitted and feels so much better Awaiting the plinth for the drivers mirror, apparently lotus only process orders on Wednesday so i have to wait till next week.....if anyone has a spare drivers side please let me know otherwise i will bodge something on for Friday as need to get it MOT'd or the insurance will be cancelled Link to comment Share on other sites More sharing options...
Steve J Posted July 24, 2013 Share Posted July 24, 2013 Awaiting the plinth for the drivers mirror, apparently lotus only process orders on Wednesday so i have to wait till next week.....if anyone has a spare drivers side please let me know otherwise i will bodge something on for Friday as need to get it MOT'd or the insurance will be cancelled Eliseparts Used Parts Sale section has a number of wing mirrors and plinths. Link to comment Share on other sites More sharing options...
