Oil cooler
Mark farmer
Hi I'm new to lotus forum I have a lotus elise s2 k series standard 2001. I was wandering if the car has a oil cooler fitted up front as I have noticed a few drops of oil on the passenger side I'm not sure if it's my car or another kind regards mark farmer
  • Replies 4
A standard K-series S2 doesn't have an oil cooler.  Some people have fitted them, although not usually up front.  I think the 111S had an oil cooler as standard.  Are you sure it is engine oil?  Could it be brake fluid?  Damper fluid?
Hello and welcome :bye:
As above:  It didn't have an oil cooler and it would be located there if it did.    Have you got any pictures - both of the leak and the car ?
Your usual suspects are:
a) brake fluid
b) damper fluid
c) coolant
d) washer fluid (?)
e) Another car with a oil leak parks in the same spot as you.
Good luck
MrWill
  • 2 weeks later...
Lol, welcome to the world of K series paranoia, mines usually more to do with constant smell of coolant even though I know its all fine! 😂
Get A sheet of cardboard and put under, that way you will know if it's your car and where about it's dripping from :)
and Welcome to the Forum:tup:
