Glyn B Posted April 7, 2021 Posted April 7, 2021 Hi all I have just popped round to Top Gear in Wolverhampton and found it all shut up. Really gutted. He did my head gasket on my Elise S1 and did a fantastic job. Does anyone know where I can get some work done as need my rear brake pipes replacing which requires the petrol tank removal so not a job I want to do myself. I am in Shropshire but go over to Derby regularly. Any help would be great. Thanks Glyn
daves2111s Posted April 7, 2021 Posted April 7, 2021 You could try DRM Motorsport in Kidderminster. Kevin and Dan are great guys with loads of race prep and build experience in everything from Elise’s to BTCC. I’ve used them for all my Elise work for 10years+ and very happy too!
Phil Hutchins Posted April 7, 2021 Posted April 7, 2021 If in North Shropshire there’s Blink Motorsport in Winsford. I’ve used them together with TG but as you’ve found out, Martin has ‘retired’ from his garage although I did read that he does mobile mechanic work locally. As you travel to Derby, I’m sure others will soon be on to recommend PJS or Unit4.
@ndy Posted April 7, 2021 Posted April 7, 2021 Hi Glyn, Removal of the petrol tank is not as bad as you may think, I had to do the same with my S1 to replace the brake pipes, take a look at this TechWicki - https://wiki.seloc.org/a/Fuel_Tank,_Removal_and_Refurbishment
hartleyj Posted April 10, 2021 Posted April 10, 2021 On 07/04/2021 at 21:59, Phil Hutchins said: If in North Shropshire there’s Blink Motorsport in Winsford. I’ve used them together with TG but as you’ve found out, Martin has ‘retired’ from his garage although I did read that he does mobile mechanic work locally. As you travel to Derby, I’m sure others will soon be on to recommend PJS or Unit4. Yes, big thumbs up for Gav at Unit 4 and also PJS.
Elisemadray Posted April 10, 2021 Posted April 10, 2021 As Above, I would go with Gav at Unit 4 or PJS just outside burton both will do a first class job
