PJT Posted April 16, 2018 Share Posted April 16, 2018 Does anyone know of a good app to plan routes with. I want one where you can pick a destination then point and “pin” waypoints to keep you off motorway, away from built up areas/ traffic and on B roads. i’m on Apple Link to comment Share on other sites More sharing options...
Elisemadray Posted April 16, 2018 Share Posted April 16, 2018 46 minutes ago, PJT said: Does anyone know of a good app to plan routes with. I want one where you can pick a destination then point and “pin” waypoints to keep you off motorway, away from built up areas/ traffic and on B roads. i’m on Apple do yo have access to a pc or windows device? if you do I can explain how you can map a route and create a GPX file, I believe there are Apps to use on a IPhone you but that part involves buying an app and is still complicated. I brought a Tomtom Go which will direct you on your route, is also hands free which is handy, sorry I cant be more help on the apple front. Link to comment Share on other sites More sharing options...
kayj_prod Posted April 16, 2018 Share Posted April 16, 2018 You can build a route plan on Google Maps on your desktop (obviously Mac or PC). If you mean that you’re using an iPhone, then there’s no way to transfer a route plan over to your mobile device and Google Maps on iPhone doesn’t support multiple way points. Apple Maps definitely doesn’t either! I use an app called Copilot- used it for years. Yes, it’s paid, but you only need to buy the geographic areas you need. I’ve used it for navigating in a lot of countries without any issue and as you download maps to your device, you don’t need data for it to work. The only issue I have had is here in the UAE where the map data can lag behind the rate of road building and road closures/diversions. You can enter way points, choose to avoid motorways/tolls etc. save and load routes, and it will dynamically adjust your route if you make a mistake or if traffic delays warrant it. HTH Link to comment Share on other sites More sharing options...
marky_p72 Posted April 16, 2018 Share Posted April 16, 2018 I've tried planning on Google maps, but I think you are limited to only 10 'marker' waypoints? I also have co-pilot, so I will try that again myself. Link to comment Share on other sites More sharing options...
chrisdb Posted April 22, 2018 Share Posted April 22, 2018 I’ve just got a new sat nav app called ‘Scenic’ on my iPhone. It seems to have been developed for bikers and easily lets you build routes with waypoints and navigate them. Even has options for ‘efficient’ or ‘curvy’ routing when you just select start and finish points. It’s free with a paid option for some advanced features but I haven’t needed to use any of them yet. Link to comment Share on other sites More sharing options...
Elisemadray Posted April 22, 2018 Share Posted April 22, 2018 3 hours ago, chrisdb said: I’ve just got a new sat nav app called ‘Scenic’ on my iPhone. It seems to have been developed for bikers and easily lets you build routes with waypoints and navigate them. Even has options for ‘efficient’ or ‘curvy’ routing when you just select start and finish points. It’s free with a paid option for some advanced features but I haven’t needed to use any of them yet. Thanks Chris will have a look Link to comment Share on other sites More sharing options...
PJT Posted April 23, 2018 Author Share Posted April 23, 2018 Chris, that looks great. Are you using it without voice guidance? Link to comment Share on other sites More sharing options...
chrisdb Posted April 23, 2018 Share Posted April 23, 2018 Yep, I just have my phone mounted on the dash. Link to comment Share on other sites More sharing options...
Jonathan E Posted April 23, 2018 Share Posted April 23, 2018 Try this https://www.myrouteapp.com/en plan your route then export it in whatever format you wish. I export them as GPX or .itn for use in my TomTom. Great app been using it for quite a while and has let me down once Link to comment Share on other sites More sharing options...
