JonS
JonS
Extending The Knock Limit Of A Turbocharged Gasoline Engine Via Turboe
ABSTRACT
Turboexpansion is a concept which is aimed at reducing the fuel
consumption of pressure-charged gasoline engines by providing overcooled
air to the engine in order to extended the knock limit (relative to a
conventional charge-cooled system). An extension to the knock limit
allows several possible shifts in the compromise adopted in pressurecharged
gasoline engines, including increased specific output, an increase in
trapped compression ratio or a reduction in the octane appetite of the
engine. All are considered important in the drive to reduce the CO2 output
of passenger cars fitted with gasoline engines against the backdrop of the
ACEA commitment of 140g/km of CO2 per km by 2008.
The present work reports on initial results from running a singlecylinder
engine under conditions of varying temperature at fixed charge-air
densities to assess the worth, in combustion terms, of pursuing reduced
charge-air temperature to extend the knock limit. To enable this, a chargeair
conditioning rig has been constructed based on three positivedisplacement
superchargers and heat exchangers. This device is capable of
providing close control of the charge air required for this testing
programme.
It has been shown that reducing the charge air inlet temperature, at a
fixed density, provides an extension to the knock limit of up to 3.5° of spark
advance at high compression ratio for a temperature reduction from 40 to
20°C at 2000rpm.
User Feedback
  • Adventures of an S1 Elise in Germany
    Some of you will know, but for the rest, I'll be working in Germany near Mannheim until end of 2026 with 75% of my time there, and 25% back home. As i fancy doing some different roads, and I've booked two weekend driving tours with Delightful Driving company (run by Elisa Artoli), on Thursday 10th July I'll be setting of in my S1 Elise, and 4 days later I plan to arrive at my apartment. I plan to post about my driving adventures over there, so keep an eye on this blog should you be int
    Badger02
    Badger02
    Touring
    Exige V6 - Rear tyres
    Guido
    Guido
    Technical Talk 7
    Formula One
    Maddox
    Maddox
    General Talk 20
    Elisemadray
    Elisemadray
    General Talk
    Elise S3 Brakes
    Trebor_UK
    Trebor_UK
    Technical Talk 16
  • MLOC classifieds
  • MLOC garage
  • Member Statistics
    4,444
    Total Members
    1,800
    Most Online
    mattlawson76
    Newest Member
    mattlawson76
    Joined
