The Z20LET on standard internals was always at its limit with the 380ft lb torque my stage 4 was pushing out so it's all going in the next 2 weeks to be replaced with -
Z20LEH engine with FCP Forged rods & ARP bolts
Garrett GTX2867R (with .64 housing) - Dual billet ball bearing 'GTX' series Turbo which spools faster than a GT2871 and holds nearly as much power as a GT3071!
Tial 44mm external wastegate
Klassen Inlet manifold
Thermal gaskets
Klassen 'V' band exhaust manifold
630cc Injectors
Enlarged 62mm Throttle body
6 Paddle clutch & uprated cover
Vibratech engine mounts
& a lot of heat shielding & DG trickery!
All booked into CS for mapping on the 19th Sept with Klassen in Germany on standby!
Not looking for headline numbers in fact I don't want anything really over 400bhp even though the engine & turbo would be easily good for 450/460, the brief for CS/Klassen is drivability and mid range, minimal lag useable power & when talking to Mark @ CS he just said 'thats going to be phenomenal!'
Taking the opportunity to make sure it all looks as good as its going to perform and sent the rocker cover off to 'Wicked Coatings' for them to finish it in a gloss brushed alloy finish with gloss black plug cover and have to say that they have really done a fantastic job!
So its all happening, every things here, every things in place, just needs a bit of DG magic now!
View Garage
