marky_p72 Posted April 25, 2022 Share Posted April 25, 2022 I have recently purchased a soft top (second hand) from a reputable Lotus dealer but it just doesn’t seem to sit right. There’s a bit of a dip at the front. It’s a 2015 s3 Elise. Does anyone know if adjusting the tensioners will correct this? I’m sure the roof on my old 2007 s2 elise was tighter than this. Thanks Mark Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
PJT Posted April 25, 2022 Share Posted April 25, 2022 Do you think it’s a bit stretched? It might relax if you clean it, soak it then treat it. I use autoglym fabric hood cleaner. Link to comment Share on other sites More sharing options...
marky_p72 Posted April 25, 2022 Author Share Posted April 25, 2022 It seems a bit stretched in the length front to back. I'm not sure if your suggestion will work without trying it. I am wondering whether adding tension to the adjusters will pull it into the channels more? Link to comment Share on other sites More sharing options...
Martin 111S Posted April 26, 2022 Share Posted April 26, 2022 Be aware if you tighten the tensioners too much, you'll just snap the cable at the fitting where it bolts to roof. Link to comment Share on other sites More sharing options...
marky_p72 Posted April 26, 2022 Author Share Posted April 26, 2022 35 minutes ago, Martin 111S said: Be aware if you tighten the tensioners too much, you'll just snap the cable at the fitting where it bolts to roof. Yes, I was a bit weary about adjusting it. Thanks for the heads up! Link to comment Share on other sites More sharing options...
MG4Lotus Posted April 26, 2022 Share Posted April 26, 2022 Hi Mark, no idea about the soft top unless you put it into a washing machine on a hot cycle and see if it shrinks 😄. Did i see you yesterday lunchtime with the roof? Mark Link to comment Share on other sites More sharing options...
marky_p72 Posted April 26, 2022 Author Share Posted April 26, 2022 25 minutes ago, MG4Lotus said: Did i see you yesterday lunchtime with the roof? I don't think so?? I just popped out in it 10-10:30 (Peterborough) Link to comment Share on other sites More sharing options...
MG4Lotus Posted April 26, 2022 Share Posted April 26, 2022 It must have been somebody else with a roof being looked at Link to comment Share on other sites More sharing options...
