Ray Mulholland Posted October 13, 2005 Share Posted October 13, 2005 Guys, I'm thinking of ways to try to soundproof (as much as is possible) my S1 and thought maybe the undertrays could be insulated? I've come across this on www. woolies-trim.co.uk: Sound and Vibration Damping Pads. 1.6mm (just under 1/16") thick. Self Adhesive. For inside doors, roofs, bulkheads and floors. Dark grey, "bitumastic-type" material. Cut to size/shape BEFORE backing paper is removed. Make sure that surface to be applied is completely clean. Peel backing and press firmly into place. Both pad and adhesive can withstand temperatures between minus 30 degrees and + 120 degrees Centigrade and are highly resistant to aging. For best results the pad and application surface should NOT be below room temperature. Pad approx. 51cm x 18cm (20" x 7") ............................................... £2.13 each Full Sheet approx. 107cm x 102cm (42" x 40") ............................... £17.02 each Has anybody soundproofed their undertrays and does anybody have a view on whether the stuff above is suitable? Cheers all Ray Link to comment Share on other sites More sharing options...
ally Posted October 13, 2005 Share Posted October 13, 2005 I have just spent £750 making my S1 louder. Proberly a lot easier to just buy an S2 To be honest i dont no if you can sound proof the undertray. Lots of issues with corrosion etc. ???? In all seriousness it may be worth finding out how they have sound proofed the S2 and VX. Ally Link to comment Share on other sites More sharing options...
dobbo Posted October 13, 2005 Share Posted October 13, 2005 I coated the undertrays of Sonya's with Dynamat. I also did the shelf above the fuel tank, the front of that bit and the floors under the seats. It made no difference at all to the noise, and makes the undertrays harder to handle when servicing - they're now probably 3 times heavier. If you do do it, remember to tell the garage as they'll want to kill you when the undertrays fall (because they weren't expecting the weight) and they slice their hand trying to catch it... Chris EDIT Floor mats reduce the noise from all the road crap that hits the underside of the car and a full carpet set also helps (came with the car.....) Link to comment Share on other sites More sharing options...
malbon Posted October 13, 2005 Share Posted October 13, 2005 not a great idea. my old silver elise was really quiet. the panel under your seat must be about a mil thick and loads of noise comes from there. I dynamated the whole floor and under the seats and then put the full carpet set down. cut out loads of noises and was snuggly for the winter. they'll call you a poof though Link to comment Share on other sites More sharing options...
dobbo Posted October 13, 2005 Share Posted October 13, 2005 they'll call you a poof though <{POST_SNAPBACK}> Maybe not Jon - he's got an S1 after all... Link to comment Share on other sites More sharing options...
malbon Posted October 13, 2005 Share Posted October 13, 2005 i was the butt of endless jokes ! it looked great though and i got it for half price ! weighed hardly anything and as for an everyday driving eliser, it was one of my best mods Link to comment Share on other sites More sharing options...
Steve J Posted October 13, 2005 Share Posted October 13, 2005 they'll call you a poof though <{POST_SNAPBACK}> We don't do that anymore Jon. Perhaps a Porsche would be quieter. Link to comment Share on other sites More sharing options...
christurbo Posted October 13, 2005 Share Posted October 13, 2005 The elise makes my CTR feel like a Rolls Royce Link to comment Share on other sites More sharing options...
Martin R Posted October 13, 2005 Share Posted October 13, 2005 I like the loud noises. It the little noises i have not heard before i worry about Link to comment Share on other sites More sharing options...
Steve J Posted October 14, 2005 Share Posted October 14, 2005 Didn't think you'd like heavily insulated undertrays Martin Link to comment Share on other sites More sharing options...
Carlylove Posted October 14, 2005 Share Posted October 14, 2005 On cold days with the roof off on my trips to Manchester (65m through derbyshire) I use ear plugs as the cold wind gives me a headache (yes I am stubborn & I want the roof off too much). That stops noise for me as a by product. Same effect less messin Link to comment Share on other sites More sharing options...
