2011 European Grand Prix View
2010 Timing:
Qualify Result:
P1 VET 1.37.587 Q3
P2 WEB 1:37.662 Q3
P3 HAM 1:37.969 Q3
TL best P19 TRU 1:40.658 Q1
2010 Race Result:
P1 VET 1:39.141 L52
P2 HAM 1:39.156 L56
P3 BUT 1:38.766 L54
TL best P21 TRU 1:41.770 L53
Quick description:
Longitudinal "stop and go" track
Many hard braking & traction areas
Very smooth track surface with no bumps and kerbs are not an issue
Run very low ride height but plank wear is high due to kerb usage
Possible high impact load on steering column when driver use kerbs through the T18 - T24 high-speed section
Overtaking is difficult and hard on brake temperature & wear
Overall grip gradually increases over weekend as the circuit is used infrequently
Typical balance issue:
Braking and traction stability are the main issues
Gears ratio (1st gear/others):
1st gear used 4/5 times each lap in T8, T10, T17 and T25
Circuit Sensitivities:
Bumpiness: Very smooth
Overtaking chance: Very low
Kerbs: Low / medium
Engine severity: High
GBX severity: High
Lat/Long grip: Longitudinal
RH setting particularity: Low front RH possible
Aero eff ratio: High
Track grip evo during WE: Very high
Aero settings: Medium / high
Brake wear severity: High
Brake cooling necessity: High
Team Lotus Partners:
Pirelli tyre compounds in Valencia: Medium (Prime) / Soft (Option)
Jarno Trulli, Car 21 - Chassis T128-01: "I left a very wet Canada and headed to my home in Miami for a few days of sun before returning to Europe for the next race. Despite the finishing position in Canada I was really pleased with my performance there across the whole weekend. It was a tough race for sure and I've already said that I think the FIA played it just right. At times it was obvious that the cars were undriveable in the conditions so when they stopped the race, and brought out the safety cars, it was exactly the right times to do so. I finished the race with the inerter dangling around between my legs - the guys on the pitwall were urging me to bring it home and while it would have been easier to park it, it's times like that when you have to do whatever you can to help the team. Having a large lump of metal hanging about was definitely holding me back and I wasn't able to push as hard as I'd have liked, but it was still pretty satisfying to catch the guys ahead and finish just behind them as we crossed the line.
"Now it's Valencia. It's another temporary circuit and a good challenge for the drivers whilst also being very safe. In contrast to Canada the track surface in Valencia has strong evolution over the weekend - It starts out dusty on Friday but by Sunday there is a lot of grip and the lap times come down all weekend. It's a track where you need to find a rhythm. Sections of it flow but then you have other areas that are very much stop and go - long straights with hard braking at the end into tight corners. First gear is used a lot more here than most tracks and often at the end of a flat out straight so the brake wear is high. I'm looking forward to it - the Spanish fans are some of the most passionate in the world and they've taken Team Lotus to their hearts so I think it will be a good weekend for us all round."
Heikki Kovalainen, Car 20 - Chassis T128-04: "Straight after Canada I headed down to New York with Tony, Mike, Ansar Ali from Caterham Cars and some of the team to take part in the GE announcement. We had a very good couple of days in NYC and at GE's HQ and I'm really pleased for the whole team that we've been able to bring GE on board. Signing them up is massive news for us and is exactly the sort of partner Tony and Mike told me they were targeting when I first joined the team in 2010.
"After New York I went home for a few days before the trip to Valencia. I'm looking forward to the European GP as I think the heat and the demands of the circuit should suit our car well. It's not exactly a street circuit, it's a semi-street circuit with a very smooth track surface with almost no bumps and low kerbs. It has long straights and a number of tight corners that means finding the right downforce level is critical to maximising performance. Pirelli is bringing the softs (option) and the mediums (prime) which we haven't raced yet this season so I think we will have some work to do on Friday to look at how to get the most out of them. We've been easy on the tyres all season so hopefully that will be the case again in Valencia, giving us strategic options that we've used well all season - Q2 is still the goal for qualifying and then let's see what happens on Sunday."
Mike Gascoyne: "We learnt a number of important lessons in Canada and that weekend is now behind us and we are straight on to Valencia.
Before leaving North America I was lucky enough to go GE's General Research Centre to be shown around, just after Tony had announced our partnership with them. From an engineering perspective the whole operation is breathtaking.
"Now it is back to Spain and the European Grand Prix. In terms of downforce levels Valencia is unlike most of the other tracks in the calendar - we run more wing than in Canada for example, but less than a number of the other tracks like Barcelona or Turkey. The prime tyre here is the medium which we are racing for the first time this season. We ran it in on Friday in Canada and it behaved pretty well but as degradation can be reasonably high on Fridays in Valencia, due to the amount of dust and sand on track, we will be looking closely at how it performs and how we can take advantage of the time difference between the primes and the options on Saturday and Sunday."
Tony Fernandes: "The Canada weekend was definitely one of highs and lows. Our performance in qualifying was especially pleasing and the aim is to build on that again in Valencia and throughout the season, but the race was obviously a missed opportunity. It is important that we learn from that experience, cut out the same mistakes again and make sure we are in the right place to take advantage of such extraordinary circumstances in the future. It is all part of the learning curve and you have to have the lows to truly appreciate the highs.
"With that in mind it felt like perfect timing to go straight to the US and unveil our partnership with GE. Just before I went on CNN to make the announcement I was shown a picture of all of our staff back in Hingham crowded around a TV waiting to see me make the announcement and that was a special feeling. GE is obviously good news but seeing how much it meant to the people back at the factory drove home just how important that announcement is for each and every one of us in Team Lotus. We have definitely taken a huge step forward with the GE partnership and, on a personal level, I am delighted that a company that has supported AirAsia since day one has seen the same potential in this team. We are still very much in our infancy so to attract a brand of the calibre of GE at this early stage in our development sends out a very strong message to our fans, existing and future partners and the other teams in the pitlane that we are going to be a force to be reckoned with for many years to come.
"Now our attention turns to Valencia. This is our sixth trip to Spain this year and a venue I particularly enjoyed in 2010. Valencia is similar to Montreal and Monaco in the way Formula 1 is embraced across the whole city and that level of support creates a fabulous atmosphere, on and off track. On track the goals are clear - repeat the qualifying performance from Canada and keep up our much improved reliability record to bring both cars home on Sunday. It would also be good if the other drivers on the grid could avoid using either of our cars as launch ramps this year..."
User Feedback
  • Adventures of an S1 Elise in Germany
    Some of you will know, but for the rest, I'll be working in Germany near Mannheim until end of 2026 with 75% of my time there, and 25% back home. As i fancy doing some different roads, and I've booked two weekend driving tours with Delightful Driving company (run by Elisa Artoli), on Thursday 10th July I'll be setting of in my S1 Elise, and 4 days later I plan to arrive at my apartment. I plan to post about my driving adventures over there, so keep an eye on this blog should you be int
    Badger02
    Badger02
    Touring 5
    LitP 2025 photos
    Does anyone have any good photos of this year's LitP that they wouldn't mind sharing? Absolute Lotus magazine would like to publish a short report of the event and need some photos. Ideally I think they would like a selection of pics from the entire weekend so bbq, pootle, runs, Sunday breakfast stop the procession down Winnats Pass and Bamford. Photos of the people aswell as the cars are also welcomed. If you have any and are happy for them to go in the magazine without a credit or pa
    DeanB
    DeanB
    General Talk
    Exige V6 - Rear tyres
    Guido
    Guido
    Technical Talk 8
    [Group Lotus Video]Team Lotus is back
    Team Lotus is backView the full article
    News Bot
    News Bot
    General Talk
    Formula One
    Maddox
    Maddox
    General Talk 20
  • MLOC classifieds
  • MLOC garage
  • Member Statistics
    4,444
    Total Members
    1,800
    Most Online
    mattlawson76
    Newest Member
    mattlawson76
    Joined
