Martin R
Martin R
My2007 Lotus Sport Exige Cup
Performance through Lightweight
MY2007 Lotus Sport Exige Cup –adrenaline boosting fun from the
latest Lotus track car – USA Specification
Los Angeles, CA (November 30 2006) – Lotus Cars USA, the subsidiary of Lotus Cars in
North America, today unveiled the MY2007 Lotus Sport Exige Cup. Unveiled at the Los Angeles
International Auto Show, the 252 hp, supercharged and intercooled sportscar is a completely
out-of-the-box track car with a specification designed to prepare the budding driver for the grid
at some of the finest and most challenging circuits in North America.
Weight has been kept to an ultra low 1800 pounds and the phenomenal power to weight ratio
has been further enhanced by increasing the power output from 243 hp to 252 hp. Weight
saving (or adding lightness!) has been achieved through the effective use of lightweight
materials and through the eradication of all non-essential components such roof trim, carpets,
front mudflaps, central locking and bulkhead trim. Of course just having fantastic power to
weight doesn't make a car a high performer on the track, so the Lotus Sport Exige Cup has a list
of standard equipment that includes track only slick tires, uprated 4-piston front brakes,
adjustable dampers and adjustable anti-sway bar, the latest SCCA-compliant roll cage, FIA
approved Lotus Sport branded driver's seat with six-point driver harness (there is no passenger
seat) and a lightweight rear screen (instead of glass). The options are even more race focused
with a FIA approved 70 litre fuel cell, air-jack system and level two stainless steel exhaust with
de-cat pipe, a plate type limited slip differential and Star Shield.
The Lotus Sport Exige Cup is one of the quickest cars around a circuit. Key to this incredible
performance is the aerodynamic package, which produces over 90 pounds of downforce at 100
mph increasing grip and ultimately safety at higher speeds.
With a top speed of close to 160 mph and a zero to 100 mph slingshot in just less than 9.8
seconds (the 60 mph sprint takes just under 3.9 seconds), the MY2007 Lotus Sport Exige Cup
is the perfect partner to a serious track day enthusiast. Even the most exotic supercars would
struggle to keep up! At a MSRP of just $84,990, plus options, delivery and taxes, customer will
have to queue on a first ordered, first delivered basis.
Further details about the Lotus Sport Exige Cup:
Engine
The supercharged and intercooled engine in the Lotus Sport Exige Cup has a maximum power
output of 252 hp at 8000 rpm and a torque figure of approximately 179 lb-ft, at 7000 rpm. This
vast amount of extra power and torque now available means that the cam change between the
low-speed cam and the high-speed cam is variable to ensure that there is a smooth and linear
surge of power from low engine speeds all the way to the maximum 8000 rpm. The Roots-type
Eaton M62 supercharger (with a sealed-for-life internal mechanism meaning that it does not
require the use of the engine's oil) is run from the crankshaft and has an integral bypass valve
for part load operation. Charge air (air under pressure from the supercharger) is cooled through
an air-to-air intercooler (the cooling air enters via the roof scoop) before being fed into the
engine itself. All charge air ducting has been kept as short as possible with large diameter pipes
making sure that the bends in these ducts are not too tight, to the benefit of throttle response
and efficiency. Four high capacity injectors add additional fuel under hard acceleration or high
speed driving.
A sports-type clutch plate and heavy duty clutch cover transfers the engine power and torque to
the lightweight C64 six-speed gearbox (with an aluminum casing) – with the same perfectly
spaced ratios as the Exige S. A plate type limited slip differential is fitted as an option as is the
Lotus switchable traction control system (LTCS). The LTCS system works through the engine,
reducing power to maintain traction, is active above 5 mph and operates much more quickly
than many brake-based systems.
An Accusump (engine oil accumulator unit) is included in the whole package as an oil reservoir
backup for extreme track use ensuring that, under these conditions, the engine oil pressure
remains constant.
Twin oil coolers complete the powertrain package.
Wheels and Tires
5-spoke lightweight forged alloy wheels in silver are shod with Lotus specific Yokohama slick
tires to maximise grip and achieve the ride and handling targets set by Lotus.
Brakes
The brake system includes large diameter 308 mm 2-piece aluminum belled cross drilled and
ventilated front discs and 282 mm cross-drilled and ventilated discs at the rear, upgraded Pagid
RS14 sports brake pads set into the brake calipers (AP Racing two piece radially mounted, 4
piston at the front and Brembo sliding at the rear), high grade silicone brake fluid, stainless steel
braided brake hoses all linked to the proven Lotus track tuned servo-assisted four-channel ABS
system that enhances braking performance and minimising stopping distance without taking
over from the skill of the driver.
Suspension
Suspension is provided by Öhlins springs and two-way adjustable dampers (which have 22
compression and 60 rebound settings and ride height adjustable perches to reduce the ride
height from 130 mm to 120 mm) and an adjustable front anti-sway bar (five settings). Full
instructions and recommended settings are provided to allow customers to tailor the handling
characteristics of the car to their own requirements.
As the Lotus Sport Exige Cup cars are modified for track use, a double shear track control arm
brace is provided to cope with the expected kerb abuse during racing and hard track day
driving.
Safety Equipment
The Lotus Sport Exige Cup cars have the safety equipment that is expected for a track car with
6-point seat belt harness on the driver's side (with an FIA approved Recaro / Lotus Sport seat) –
there is no passenger seat. The full roll cage is SCCA compliant and completing the additional
safety equipment is a mechanical ignition kill switch with cockpit and external activation and a
plumbed electrical fire suppression system, again with cockpit and external activation.
Exhaust System
A "Level One" stainless steel sports exhaust is fitted with the bifurcated exhaust pipes exiting
from the centre of the anodized-finished 3-piece rear diffuser. A "Level Two" stainless steel
exhaust with de-cat pipe is a no cost option.
Option costs:
FIA approved 70 litre fuel cell – $3095
Lotus Sport limited slip differential (plate type) – $1595
Lotus Traction Control System – $495
Air jack system (special conditions apply) – $5495
Air-conditioning – $2495
Metallic paint – $590
Lifestyle Paint – $1200
Star Shield protection – $995.
Pictures in the gallery here:
http://www.midlandslotus.co.uk/forum/index...d=sc&cat=97
User Feedback
  • Formula One
    Maddox
    Maddox
    General Talk 20
    Elisemadray
    Elisemadray
    General Talk
    Elise S3 Brakes
    Trebor_UK
    Trebor_UK
    Technical Talk 16
    MrWill
    MrWill
    Technical Talk 17
    Boot lid hinge pin? S2 Elise
    foxy76
    foxy76
    Technical Talk
  • MLOC classifieds
  • MLOC garage
  • Member Statistics
    4,443
    Total Members
    1,800
    Most Online
    robbo101
    Newest Member
    robbo101
    Joined
