chris_h
chris_h
Lotus Evora - Technical Specifications
Headline figures
Max Power 280PS @ 6400 rpm
C02 emissions 205 g/km
Weight 1382 kg
0-60 mph 4.9 seconds
0-100 km/h 5.1 seconds
Top speed 162 mph /261 km/h
Fuel economy 32.5 mpg - 8.7 l/100km (combined cycle)
Vehicle Description Technical Specifications
Engine Mid-mounted, transverse, 3456 cc, DOHC Dual VVTi
Engine management Lotus T6e engine control unit
Swept volume (Bore x
Stroke)
94 x 83 mm
Compression ratio 10:1
Max Power 280PS/ 206 kW/ 276 hp @ 6400 rpm
Max Torque 350Nm/ 258 lbft @ 4700rpm
Specific power output
(PS/ litre)
81
Cylinder head material Aluminium
Engine block material Aluminium
Number of crankshaft
bearings
4
Number of camshafts 4
Fuel supply system Returnless Fuel injection
Idle running speed 600-680 rpm (variable)
Ignition 1 spark plug per cylinder
Steering Lotus tuned power steering
Turn radius 10.14 m
Steering lock to lock 2.86
Service interval 9000 miles
Warranty 3 year 100,000km (60,000 miles) whole vehicle warranty with
8 years chassis perforation warranty for EU markets
Fuel Petrol 95 RON
Performance Figures
Maximum speed 162 mph
Maximum speed 261 km/h
0-100 mph 12.3 seconds
0-160 km/h 12.2 seconds
60-0 mph 33.6 meters – 2.4 seconds
100-0 mph 88.6 meters – 3.9 seconds
100-0 km/h 36.8 meters – 2.5 seconds
160-0 km/h 89.5 meters – 3.9 seconds
Transmission
Gearbox 6 speed manual
Clutch Single plate
Differential Open type
Transmission ratio Sports Standard
1st 3.538 3.538
2nd 1.913 1.913
3rd 1.407 1.218
4th 1.091 0.86
5th 0.9697 0.79
6th 0.8611 0.638
Reverse gear 3.831 3.831
Final drive 1st - 4th 3.777 3.777
Final drive 5th- 6th 3.238 3.238
Emissions
Emissions Euro 4 compliant
Fuel economy Combined 32.5 mpg – 8.7 litres / 100km
Fuel economy Urban 22.8 mpg – 12.4 litres / 100km
Fuel economy Extra
Urban
43.5 mpg – 6.5 litres / 100km
Fuel tank capacity 60 litres usable volume
Fuel system Stainless steel fuel tank with Onboard Refuelling Vapour
Recovery to capture hydro-carbon vapour given off during
refuelling
Exterior Dimensions
Overhang Front 993 mm
Overhang Rear 774 mm
Ground clearance 120 mm
Overall length 4342 mm
Overall height - 1223 mm
Overall width 1848 mm
Wheelbase 2575 mm
Track Front at ground 1567 mm
Track Rear at ground 1575 mm
Design front ground
clearance
125 mm
Design rear ground
clearance
147 mm
Chassis
Power to weight (PS/
1000 kg)
203
Chassis
Lotus designed VVA (modular lightweight bonded Aluminium
structure)
Vehicle torsional stiffness 26 600 Nm per degree
Front suspension
Double wishbone suspension, antiroll bar, Eibach springs and
Bilstein dampers
Rear suspension
Bilstein dampers
Wheels
Cast wheels - Silver or Stealth Grey (option) – 18" x 8" front &
19" x 9.5" rear
Forged wheels (option) –Silver or Anthracite – 18" x 8" front &
19" x 9.5" rear - (3.2 kg lighter)
Front tyres 225/40 ZR18 Pirelli P-Zero
Rear tyres 255/35 ZR19 Pirelli P-Zero
Total chassis weight 206 kg
Front module 25 kg
Rear module 58 kg
Chassis tub 100 kg
Seatbelt anchorage frame 23 kg
Weight distribution 39% Front - 61% Rear
GVW 1782 kg
Vehicle mass 1382 kg
Brakes
Operation Servo assisted brakes
Anti lock brakes Lotus tuned Bosch ABS system
Brake technology Hydraulic Brake Assist, Electronic Differential Lock and
Electronic Brake Distribution
Brake calipers AP-Racing four-piston calipers (front and rear)
Front discs 350 mm ventilated (cross drilled optional)
Rear discs 332 mm ventilated (cross drilled optional)
Hand brake Drum in hat
Aero
Drag (Cd) 0.33
Drag (Cd.A) 0.627
Front downforce 3 kg at 100 mph (160 km/h)
Rear downforce 5 kg at 100 mph (160 km/h)
Aero package features Rear diffuser, splitter, flat underbody and floating rear wing
Related images are here:
http://www.midlandslotus.co.uk/forum/index...=sc&cat=178
User Feedback
  • Formula One
    Maddox
    Maddox
    General Talk 20
    Elisemadray
    Elisemadray
    General Talk
    Elise S3 Brakes
    Trebor_UK
    Trebor_UK
    Technical Talk 16
    MrWill
    MrWill
    Technical Talk 17
    Boot lid hinge pin? S2 Elise
    foxy76
    foxy76
    Technical Talk
  • MLOC classifieds
  • MLOC garage
  • Member Statistics
    4,443
    Total Members
    1,800
    Most Online
    robbo101
    Newest Member
    robbo101
    Joined
