jako999 Posted June 24, 2019 Share Posted June 24, 2019 Hi all after yesterday’s outing I’ve got in the car this morning and the instrument cluster lights are out on an 2010 S2 are they bulbs or led’s also seems a bit strange that I assume there is mor then one and they are all out? Before I strip it down any info please I can’t seem to find much about the Illumination side. Thanks Link to comment Share on other sites More sharing options...
Alpinetracks Posted June 25, 2019 Share Posted June 25, 2019 Can't help too much, but I would have strongly thought they would be LED - they have been on most of my previous cars dating back to the early 2000's. Dash brightness is adjustable isn't it too - presume you've tried the dimmer...?? Link to comment Share on other sites More sharing options...
Elisemadray Posted June 25, 2019 Share Posted June 25, 2019 On 24/06/2019 at 08:28, jako999 said: Hi all after yesterday’s outing I’ve got in the car this morning and the instrument cluster lights are out on an 2010 S2 are they bulbs or led’s also seems a bit strange that I assume there is mor then one and they are all out? Before I strip it down any info please I can’t seem to find much about the Illumination side. Thanks There is a Button on the Steering column which controls how bright on not the instrument panels is, check your handbook I doubt it's a failure but then you never know 😀 Link to comment Share on other sites More sharing options...
Martin 111S Posted June 25, 2019 Share Posted June 25, 2019 First try the dimmer button - possible you've pushed and held it in. Next remove the fuse and replace, as this resets it Had this a couple of time on my old 2008 SC - think its no. 9 IIRC ( but check handbook ) After these - its gets more painful I'm afraid. Link to comment Share on other sites More sharing options...
jako999 Posted June 25, 2019 Author Share Posted June 25, 2019 Thanks all sorted it😁 Took the dash apart and it turned out the plug had come loose in the back of the clocks. Pulled it out a spray of cleaner put it back in and bingo. Thanks again. Link to comment Share on other sites More sharing options...
