Eric Posted February 8, 2019 Share Posted February 8, 2019 Anyone know here I can obtain new Pirelli P-Zero Corsa LSs for the rear of my Evora? 275 / 30 x 20. Lovely tyres but quite a soft compound. Alternative is an all-round replacement with Michelin Pilot Sport 4Ss, which seems a bit of a shame 'cause the front Pirellis have loads of life left in them yet. Link to comment Share on other sites More sharing options...
chris_h Posted February 9, 2019 Share Posted February 9, 2019 I changed to michelin. I think its a better tyre. As much, if not more grip yet they last quite a lot longer, particularly the inside edge. Link to comment Share on other sites More sharing options...
Phil S1 Posted February 9, 2019 Share Posted February 9, 2019 I got mine from Camskills but they're out of stock so no use to you right now. I intend to change to the Michelin's next time though as Chris has done. Link to comment Share on other sites More sharing options...
CDM2018 Posted February 9, 2019 Share Posted February 9, 2019 Why is it that the Michelin PS4 such a recommendation has no other tyres been tried ? I assume the PS4 are good tyres but there must be other alternative tyres which are good if not better ? Reading some Elise drivers they seem to favour Yokohama I just wondered would that brand not extend to Evora ? i will need a couple of front tyres by summer I expect , can I mix PS4s with Pirelli’s ? Link to comment Share on other sites More sharing options...
Eric Posted February 9, 2019 Author Share Posted February 9, 2019 2 hours ago, CDM2018 said: Why is it that the Michelin PS4 such a recommendation has no other tyres been tried ? I assume the PS4 are good tyres but there must be other alternative tyres which are good if not better ? Probably because the Michelins are now the standard fit on all new Evoras. Link to comment Share on other sites More sharing options...
Eric Posted February 9, 2019 Author Share Posted February 9, 2019 5 hours ago, chris_h said: I changed to michelin. I think its a better tyre. As much, if not more grip yet they last quite a lot longer, particularly the inside edge. Ok thanks, good recommendation. And even if I could find the Pirellis, I reckon they'd be quite pricey anyway, so a full set of four PS4 might not work out much more expensive (ha - I've talked meself into it!). Link to comment Share on other sites More sharing options...
chris_h Posted February 10, 2019 Share Posted February 10, 2019 Make sure you get the right ones. Ps4 is for moderate performance saloons etc, ps4s is for sport cars. I also went up a width on the front and back to give a little rim protection. I’ve had no problem with rubbing. If you are doing low mileage summer driving then you could go for cup 2. It’s what lotus fit on the 430. Link to comment Share on other sites More sharing options...
CDM2018 Posted February 10, 2019 Share Posted February 10, 2019 So it’s seems the PS4 S is to way to go I am never likely to see a track and so my car is only weekend and school run about 6-7k max a year. would PS4 S still be ok ? Also my current 225/40 Pirelli is it case to go for extra width as I like thought to protect the rims ? Link to comment Share on other sites More sharing options...
