@ndy Posted May 3, 2014 Posted May 3, 2014 I've been meaning to tidy up the wheels on the Exige and more specifically the discs hubs all winter as the rust always p*ss*d me off when I clean my car so I took advantage of the sunshine today and finally sorted them out - This is what they looked like before - You can see the rust a little more on this one - This one shows haw bad they are when you remove the wheel - The final result after degreasing, cleaning off the rust and then spraying with Engine heat resistant paint, Much better..... I cleaned the back of the wheels while they were off and this makes a big difference close up -
Martin R Posted May 3, 2014 Posted May 3, 2014 You need to get the wheel studs replated now. Nice job.
