christurbo Posted August 4, 2005 Share Posted August 4, 2005 Ive had the car a couple of days. The atmosphere has not been really dry, hence no squeeknig. But today i just took her for a blat after work, and it squeeks over rough ground - accelerating, or braking hard. Sounds like suspension. Where exactly would it be squeeking, and should i attack the whole suspension with some WD40??? Could be the springs, links??? PS. it had all shock changed in last service. Oh and when i was under there painting my calipers, the susp looked like it needed a good brushing, and lubing. Is WD40 the best thing to use, if not what is? Where exactly should i be directing the lubing??? Thanks Link to comment Share on other sites More sharing options...
Loafing Wafu Posted August 4, 2005 Share Posted August 4, 2005 The worst squeak i had was where the metal edge of the lower part of the dash board met the metal shelf. It squeaked like hell when going over anything resembling a pebble. To solve this i but a little bit of sticky foam draught insulation tape between the two (when i say put i meant wedged using a screwdriver). It seemed to work really well. However if it's coming from the suspension i really have no idea. Link to comment Share on other sites More sharing options...
Martin R Posted August 4, 2005 Share Posted August 4, 2005 Chris, can you give a rough location of the squeak Link to comment Share on other sites More sharing options...
christurbo Posted August 4, 2005 Author Share Posted August 4, 2005 Chris, can you give a rough location of the squeak <{POST_SNAPBACK}> Im sure it is coming from the rear as it seems like its coming from below me, although it could be coming from all corners They guy who i bought it from said that he asked lotus about it and they said they would charge him £70 for greasing the ball joints???? Can i just go around all the suspension joints with some WD40? Link to comment Share on other sites More sharing options...
Jonathan E Posted August 4, 2005 Share Posted August 4, 2005 Silicone spray(Halfrauds??) works a treat,apply it to all rubber and plastic gizmo's in the suspension.Sorry for the non tecchy talk but I'm not a tecchy person. hth Regards Jon Link to comment Share on other sites More sharing options...
dobbo Posted August 4, 2005 Share Posted August 4, 2005 WD40 is NOT a lubricant - it's a water repellant. Go for a teflon spray, eg GT85 (cycling section at Halfrauds) - I use it on ARB bushes, clutch trunions, etc Link to comment Share on other sites More sharing options...
christurbo Posted August 5, 2005 Author Share Posted August 5, 2005 Right all done! I took it for a spin this morning and found it was coming from the front. So ive just taken both wheels off and saturated each joint/connection with grease. I took it for a spin so that the grease would work into the joints and 'hey presto' NOT A SQUEAK TO BE HEARD!!!!! Its funny that something as little as that can make you so so happy! Celebarations tonight Cheers guys! :up Oh and have just lubed the clutch pedal attatchment [again] as it has a horrible creeeeeeeaaaaakk Link to comment Share on other sites More sharing options...
