New Exhaust
stockhome
Hanger 111 Signature
18 members have voted
  1. 1. What exhaust tips
    • Straight Bigger
      10
    • Slashed smaller
      8
  • Replies 20
I like the look of both but probably am swayed slightly more towards the slashed ones :)
One of each? :P
[seriously - I voted for the slashed ones]
Just added my vote for straight. So wth a 50/50 split vote I'm sure that's helped make your mind up :lol:
It might just be the picture angles but the straight tips look a larger diameter than the slash cut?
You don' buy exhaust pipes to look at - which one works best
(but I would go for the gun barrels)
The exhaust is the same just different tips
Not sure about that - if the diffuser is doing its job (which it probably isn't with the large ground clearance on an Elise) then there should be a low pressure field at the back close to the ground. - this will entrain exhaust, on one hand the slashed pipe will feed into his and therby reduce the pressure in the exhaust pipe (good thing as it reduces the "pumping loss") - but on the other hand, you do get thrust from an exhaust and the straight cut pipe will direct its gas along the vehicle axis, whereas the thrust vector from the slashed pipe will be slightly downward.
Don't underestimate this effect - we could be talking of making a difference in the 0-60 time of as much as a millisecond
  • 1 month later...
Gone for the bigger ones should be fitted this thursday along with one of these
Eliseparts Silenced DeCat
and i will be able to fit the the new three stage diffusser and round grilles
i will post some photos when its done
  • 2 weeks later...
I put Straight bigger but I would select the 3rd option : single pipe on driver side
