Diy Geo
Martin R
  • Replies 17
Out of interest I thought I'd add this link to Bob van M's geo tool, something he's brought out fairly recently. It's a slightly different approach to the usual poles and strings and more portable with it. More than one way to kill a cat!... Geo tool
Ive finally finished fiddling and if ive done it right ended up with the following.
Front camber 0 degrees
Front toe out about 0.5mm either side as close as you can measure obviously.
Rear camber -1.8 degrees ( about 14.5mm on a 17 inch rim )
Rear toe in about 1mm either side as close as you can measure
I may get Dan to check this as its my first attempt. It was not to bad to do once you had got it all set up. I will finish off the blog when i have the time. Im going to see how this feels on track and take it from there. The first thing i will try is probably putting some camber on the front and see how it feels and what difference it makes.
