Japanese Grand Prix View
2010 Timing
Qualifying Result
P1 VET 1.30.785 Q3
P2 WEB 1.30.853 Q3
P3 HAM 1.31.169 Q3
TL best P19 TRU 1.35.346 Q1
Race Result
P1 VET 1.33.653 L51
P2 WEB 1.33.474 L53
P3 ALO 133.823 L53
TL best P12 KOV 1.37.620 L51
Quick description
Very high percentage of medium & high speed corners
Extremely lateral track
Ability to ride kerbs is not a priority
Multiple altitude changes and very narrow track make overtaking difficult
Very easy on brakes
Low front ride height possible (track very smooth)
Wind often changes between Fri & Sun (changed 180° in '09 & '10)
Typical balance issue
Need good balance for S1 and high speed S2 section
Gear ratios (1st gear/others)
1st gear not used on track
Circuit particularity
Bumpiness: Low
Overtaking chance: Low
Kerbs: Smooth
RH setting particularity: Low RH
Sensitivities
Engine severity: High
GBX severity: Low
Lat/Long grip: Lateral
Aero eff ratio: High
Track and base set-up
Track grip evo during WE: High
Aero settings: Medium / high
Brake wear severity: Very low
Brake cooling necessity: Low
Team Lotus Partners
Pirelli tyre compounds in Japan: Medium / Soft
Heikki Kovalainen, Car 20 - Chassis T128-04: "I headed out of Singapore on Monday and back to Europe to do a bit of work in the simulator before heading back out for the Japanese and Korean races. Singapore worked out really well for us and we all left feeling pretty good about what the new floor and diffuser had given us, and how we'd performed generally all weekend.
"Next up it's Suzuka, somewhere I think all the drivers look forward to and a track that's produced a lot of F1's greatest moments. Most guys will say 130R is the corner that really stands out - it's pretty hardcore heading in there at over 190mph and knowing you have to stay committed to avoid losing any time, but for me the best bit of the track is the whole run in S1 from T1 to T7. You go into T1 and T2 at high speed and you need to be committed to get the best out of the car through that fast, positive camber section, then from T3 right through to T7 is about the best sequence of turns we race in all year."
Jarno Trulli, Car 21 - Chassis T128-03: "I've always loved Japan so I'm really looking forward to getting back again for 2011. I have a lot of really good support out there, and the fans are always generous and happy but without the sort of pressure I get in places like Italy! On track I'd just like to have a race without some of the bad luck that struck again in Singapore. I'd had such a good start and was holding off the Toro Rosso and both Renaults well, even running 11th at one point as we went into the first round of stops, but the puncture I suffered when Alguersuari hit me was just another one of those things. Hopefully in Suzuka I can make up for that and get as much out of the car as I did on Sunday around Marina Bay."
Mike Gascoyne, Chief Technical Officer: "Suzuka is without doubt one of the classic F1 destinations, both for what happens on track, and for its place in the sport's history. The circuit is very quick, it puts a lot of demands on the tyres and the cars need to have very good high-speed stability, particularly when they are closely following a car ahead so they can keep up the pressure into the braking zones.
"130R is all about commitment, guts and the right line, and straight out of that corner and into the chicane at T16 / T17 is about the best overtaking zone on the track, but we also see moves being made into the hairpin at T11 as there are a couple of lines you can take in there and if you have good traction out you can stay ahead of someone you have passed all the way back to the chicane at the end of the lap.
Pirelli are bringing the Medium and Soft compounds to Japan and as the circuit predominantly affects the cars' lateral grip I think we will see degradation playing an even more pronounced role in Japan than it has throughout the rest of the season. With the small step forward we saw from our new aero package in Singapore I think we can use that and a bit of clever tyre strategy to take the fight again to the cars ahead, and if we can get qualifying right we have proved we can mix it in the races in midfield, so that has to be the aim again for the race - make sure both cars see the chequered flag and be there when it counts to take advantage of what happens around us."
Tony Fernandes, Team Principal: "2010 in Japan was our best race of the season - we finished 12th and 13th and essentially wrapped up our little battle for the title of fastest new team in Formula One, so it is a race and a country we hold very dear. I am delighted that we are heading to Japan next, both because it is a country that is very important to me personally, and to help The Japanese people show that their fantastic country is bouncing back from the terrible events there at the start of the year. We go around the world, doing business, racing, playing football and occasionally relaxing for a couple of hours, but we rarely have time to stop and take in what goes on around us, so it is good that we can go back to Japan now and help show that one of the greatest sporting events in our calendar is as successful, well managed and as great a spectacle as it ever has been.
"On the team side, I said after Singapore that that grand prix was just about our strongest ever race performance, and having been through the post-race reports it is very pleasing to see that our pace has definitely improved as a direct result of the upgrade package we brought out there. Jarno suffered again with bad luck, but the reliability issue that ended his race is still something we need to improve on - we may be small and we may not have the facilities of the teams ahead of us, but that does not mean our standards should be any lower than them, so we have to make sure in Japan, and at the remaining races, that we are a two car team that can help us guarantee tenth place this year. That is a reasonable aim and one everyone in the team is working very hard to achieve."
User Feedback
  • Elise S3 Brakes
    Trebor_UK
    Trebor_UK
    Technical Talk 2
    Formula One
    Maddox
    Maddox
    General Talk 12
    POWER STEERING
    Hi all who car has power assisted steering fitted to their cars. Is it really needed or does it make the driving experience better or worse  Thanks
    Timsrs
    Timsrs
    Technical Talk 4
    Toxic Green S-Cup - (Aka Grogu)
    Hi all as with most of my cars I thought I’d start a bit of a build thread. However unlike most cars which I bought and built up to be highly modified the plans for the lotus are quite different and so this will be more thread of its life in my ownership. I have also created a Facebook page called “Toxic Green S-Cup - (Aka Grogu)” containing images of its progress pre and post purchase. Build Page Guide Page 1 * Pre-purchase Photo‘s * First maintenance wash * Trip to Brands Ha
    DC2-CJH
    DC2-CJH
    Garage 24
    What a great Lotus in the Peaks 2025
    I have to say, I have got back home late Sunday afternoon and was spent, god only knows how Ray felt.  A great success too, by the whole team. What an absolutely fabulous day, nah weekend. There was great company at the BBQ, with a good range of Lotus gracing the village square. The Pootle on Saturday took us to the beautiful Carsington Water, on a beautiful Summer afternoon via beautiful roads not being used for the next days big event, so I am told, I took a wrong turn and found
    PJT
    PJT
    General Talk 7
  • MLOC classifieds
  • MLOC garage
  • Member Statistics
    4,440
    Total Members
    1,800
    Most Online
    martinf
    Newest Member
    martinf
    Joined
