Phil Hutchins Posted June 2, 2023 Share Posted June 2, 2023 I think it’ll be obvious as to where to re-attach the coil spring once I get myself folded into the Lotus-position, but where has the hair-spring come from?! Quote Link to comment Share on other sites More sharing options...
Phil Hutchins Posted June 2, 2023 Author Share Posted June 2, 2023 Now sorted; only half-Lotus position required! Quote Link to comment Share on other sites More sharing options...
Lithopsian Posted June 2, 2023 Share Posted June 2, 2023 Does the pedal come back up on its own now? Quote Link to comment Share on other sites More sharing options...
Phil Hutchins Posted June 2, 2023 Author Share Posted June 2, 2023 Yes…it was doing so before under pressure from the TB return spring but now I guess it’ll be quicker! Not really noticeable in thick trainers tho! Quote Link to comment Share on other sites More sharing options...
Christopher Lawless Posted July 17, 2023 Share Posted July 17, 2023 Was this easy to sort out? My S2 exige has just snapped the spring Quote Link to comment Share on other sites More sharing options...
Lithopsian Posted July 18, 2023 Share Posted July 18, 2023 14 hours ago, Christopher Lawless said: Was this easy to sort out? My S2 exige has just snapped the spring Assuming you have the mechanical pedal with an actual separate spring, this is an easy fix. If you're on the large size you might want to subcontract to a smaller person or remove the drivers seat to make it easier to slide head-first under the steering wheel. Is it the actual spring that is broken? Sometimes they just come unclipped. Not made any more by Lotus, but SJS have them listed: https://www.sjsportscars.com/parts-and-accessories/A117J6010F.htm Quote Link to comment Share on other sites More sharing options...
