bermudabob Posted December 6, 2004 Share Posted December 6, 2004 Does anyone have a piccy of how they shielded their arial from the engine? Just curious as to how it was done, and what was used - tin foil or otherwise... Link to comment Share on other sites More sharing options...
malbon Posted December 6, 2004 Share Posted December 6, 2004 Think Tigga! on seloc sells a grounding plate for this. But really...I reckon its down to the quality of the headunit. On my std one i could only pick up Radio 1 but on this new stereo I have it gets everything - still not perfect but loads better - with standard ariel and everything else. Link to comment Share on other sites More sharing options...
bermudabob Posted December 6, 2004 Author Share Posted December 6, 2004 mines an Alpine aftermarket unit - its not bad at times but in some areas its dead. And don't get me started on how close I have to hold my ipod + iTrip to it for it to work... Link to comment Share on other sites More sharing options...
Steve J Posted December 6, 2004 Share Posted December 6, 2004 Have a look in the garage at my car. I have a picture of what I did linked to the modification. Link to comment Share on other sites More sharing options...
Glennman Posted December 7, 2004 Share Posted December 7, 2004 I shielded my ariel from the engine bay with Foil as advised and it didnt make any difference. Don't think the head unit quality will make a difference over the £150 mark as mine still doesnt get anything and its a top of the range unit. Well pissed off with no Radio.....Think i may sell it and get engine mods Glenman Link to comment Share on other sites More sharing options...
bermudabob Posted December 7, 2004 Author Share Posted December 7, 2004 Has anyone tried a DAB radio? is that any better/worse reception wise? Link to comment Share on other sites More sharing options...
chris_h Posted December 7, 2004 Share Posted December 7, 2004 Has anyone tried a DAB radio? is that any better/worse reception wise? I think DAB will be worse as if the signal level drops you get nothing instead of it going a little bit noisy. The reception in my exige is really quite good. I only lose reception in really bad areas. The exige has a front mounted di-pole (in the front clam somewhere) Chris Link to comment Share on other sites More sharing options...
Fiona Posted December 7, 2004 Share Posted December 7, 2004 I shielded my ariel from the enginebay with Foil as advised and it didnt make any difference. Don't think the head unit quality will make a difference over the £150 mark as mine still doesnt get anything and its a top of the range unit. Well pissed off with no Radio.....Think i may sell it and get engine mods Glenman <{POST_SNAPBACK}> Maybe get one of Tigga's grounding plates? Rob, I think you should try the foil as it was 200 x improvement for us. Link to comment Share on other sites More sharing options...
bermudabob Posted December 7, 2004 Author Share Posted December 7, 2004 I'll give the foil a go first - I'm always up for a quick fix... If not, I may well contact Tigga... Link to comment Share on other sites More sharing options...
ipanter Posted December 7, 2004 Share Posted December 7, 2004 My reception gets loads better if i switch my headlamps on, dunno why but it works. It is probably the same reason why my temp gauge increases 2 degrees with every electrical device i have swiched on. I can get it to go from 98 to 90 just by switching radio, fan, main beam and headlamps off!! Link to comment Share on other sites More sharing options...
Steve J Posted December 7, 2004 Share Posted December 7, 2004 Not in the dark I hope Link to comment Share on other sites More sharing options...
bermudabob Posted December 7, 2004 Author Share Posted December 7, 2004 OK - I looked at the old arial lead - and its already got some sort of ally foil tube thing around it... so, there goes that theory... I wonder if the plate would help... Link to comment Share on other sites More sharing options...
Glennman Posted December 7, 2004 Share Posted December 7, 2004 Yeah ive contacted Tigger too see if he is still doing the grounding plates Glennman Link to comment Share on other sites More sharing options...
bermudabob Posted December 8, 2004 Author Share Posted December 8, 2004 Has anyone replaced the standard arial with an aftermarket one? If so, did it make a difference? Link to comment Share on other sites More sharing options...
Scott_Mac Posted December 8, 2004 Share Posted December 8, 2004 Sounds like you have a dodgy earth if switching the headlights on helps. DAB will help, but as said above, when the signal goes weak, it disappears, you don't just get hissing... it uses a different aerial, different broadcast etc so is better. As for the iTrip A9part from it being illegal in this country ) why not use the AUX input to the head unit, i'm guessing it has one as most Alpine units made in the last 10 years do... Link to comment Share on other sites More sharing options...
