simonk Posted March 3, 2007 Share Posted March 3, 2007 Today I started seeing an error message at the top of each page. It says IPB WARNING [2] preg_match() [function.preg-match]: Compilation failed: repeated subpattern is too long at offset 16378 (Line: 184 of /sources/classes/class_session.php) Not sure what's changed - everything appears to work as normal. Simon Link to comment Share on other sites More sharing options...
Deleted_User Posted March 3, 2007 Share Posted March 3, 2007 I see the same code. MAC OS X using Safari Link to comment Share on other sites More sharing options...
Daniel Posted March 3, 2007 Share Posted March 3, 2007 Me too, but funnily enough the site seems a lot faster than it's been recently. Link to comment Share on other sites More sharing options...
Steve J Posted March 3, 2007 Share Posted March 3, 2007 IPB WARNING [2] preg_match() [function.preg-match]: Compilation failed: repeated subpattern is too long at offset 16378 (Line: 184 of /sources/classes/class_session.php) Me too, on I.E. Looks like the screen size has been buggered about with as I can't see the right hand side and it won't scroll widthwise either. Link to comment Share on other sites More sharing options...
bermudabob Posted March 3, 2007 Share Posted March 3, 2007 IPB WARNING [2] preg_match() [function.preg-match]: Compilation failed: repeated subpattern is too long at offset 16378 (Line: 184 of /sources/classes/class_session.php) Me too, on I.E. Looks like the screen size has been buggered about with as I can't see the right hand side and it won't scroll widthwise either. preg-match? sounds a bit gynaecological to me.. Link to comment Share on other sites More sharing options...
Speedster Posted March 3, 2007 Share Posted March 3, 2007 I get the same but function.preg-match is underlined and in red, the other words are very faint so hardly notice them I get the same but function.preg-match is underlined and in red, the other words are very faint so hardly notice them Edited because i only keyed the above once but when press submit had the following error message Flood control is enabled on this board, please wait 15 seconds before replying or posting a new topic Post Data Saved! The following post data has been saved. In some cases, using your browser's back button will empty out form fields which results in the loss of any typed and unsaved material. You may select all of the text area below and copy before hitting back. Post Data Saved! I get the same but function.preg-match is underlined and in red, the other words are very faint so hardly notice them Link to comment Share on other sites More sharing options...
darren5591 Posted March 3, 2007 Share Posted March 3, 2007 From what I can gather its something to do with the template, or the PHP session ID with Invision powerboards. Link to comment Share on other sites More sharing options...
Steve J Posted March 3, 2007 Share Posted March 3, 2007 From what I can gather its something to do with the template, or the PHP session ID with Invision powerboards. Nope. That meant absolutely nothing to me Link to comment Share on other sites More sharing options...
GreyKnight Posted March 4, 2007 Share Posted March 4, 2007 My god! You mean we've overloaded the primary warp plasma conduit and we're gonna have to bypass it using the secondary EPS matrix or we're looking at a warp core breech in 30 seconds! SOMEBODY HELP US! Link to comment Share on other sites More sharing options...
Speedster Posted March 7, 2007 Share Posted March 7, 2007 Mentioned problems to a friend he reckons its check for the IP addresses when someone logs in or posts Link to comment Share on other sites More sharing options...
richbk Posted March 9, 2007 Share Posted March 9, 2007 Mentioned problems to a friend he reckons its check for the IP addresses when someone logs in or posts but thats a really dull answer, i was thinking maybe international money laundry or at least someone of seloc messing us nice folk about richbk Link to comment Share on other sites More sharing options...
Mark H Posted March 11, 2007 Share Posted March 11, 2007 Sorry was away skiing in Austria, problem fixed, it was just the check to see if the user visiting is a search engine "spider" bot or not that was playing up. Link to comment Share on other sites More sharing options...
Deleted_User Posted March 11, 2007 Share Posted March 11, 2007 it was just the check to see if the user visiting is a search engine "spider" bot or not that was playing up. That's exactly what I thought it was haha Link to comment Share on other sites More sharing options...
GCCK Posted March 11, 2007 Share Posted March 11, 2007 problem fixed, it was just the check to see if the user visiting is a search engine "spider" bot or not that was playing up. Boring. Much preferred Graham's suggestion about a warp core breach How was skiing btw? Link to comment Share on other sites More sharing options...
kimbo Posted March 11, 2007 Share Posted March 11, 2007 Wish I knew what you were talking about! Well at least I can delete some of my PM's now (couldn't get to that little box on the right) and Sco has suddenly become Scotto again. Thanks beefy - I am fully restored. kimbo Link to comment Share on other sites More sharing options...
