Lotus Sport Exige Gt3
LOTUS SPORT EXIGE GT3
TECHNICAL SPECIFICATIONS
ENGINE
1.8 2ZZ-GE engine. supercharged and
intercooled, chain driven double overhead
camshafts (DOHC) exploiting
a Variable Valve Timing & Lift - intelligent
(VVTL-i) system, Lotus T4e engine
management system, multi-point sequential
fuel injection, electronic ignition and
electronic throttle control, Lotus Sport dry
sump system with Laminova oil cooler
and, Goodridge braided hoses
EMISSIONS
Bespoke Lotus Sport tuned exhaust
system with Motorsport homologated
catalytic converter
TRANSMISSION
Hewland PCT sequential transmission, 6-
speed, with a selection of ratios available
and a limited slip differential,
Motorsport twin plate clutch and clutch
cover, switchable traction control
Chassis Lotus designed lightweight
structure of epoxy bonded aluminium
alloy extrusions, 6-point roll-cage (FIA
approved)
SUSPENSION
Fully independent race suspension utilising
unequal length wishbones all fully
spherical bearing joints, Öhlins 3
way adjustable (high speed and low
speed bump and rebound) damper with
remote gas reservoir and adjustable
ride height, adjustable front and rear
anti-roll bar and rear double shear track
control arm brace
Wheels Lotus Sport 5-spoke lightweight
forged alloy wheels, FR: 7Jx16 & RR:
8Jx17
BRAKES
Lotus/AP-Racing 4 pot fixed aluminium
alloy front brake calipers, 2 pot rear calipers,
315 mm diameter, uprated
brake pads, stainless steel braided hoses
throughout and 5 position bias valve,
synthetic racing brake fluid
BODYWORK
Carbon fibre front clamshell, rear clamshell,
roof, access panels and engine
cover, revised roof scoop for
increased intercooler efficiency, race front
splitter and larger adjustable carbon fibre
rear wing
ELECTRICAL SYSTEMS
Bespoke Raychem race wiring loom,
steering wheel mounted controls for pit
lane speed, radio, traction control
and data-management system
SAFETY / INTERIOR
6-point HANS approved safety harnesses,
6-point roll-cage (FIA approved). FIA
approved ignition kill switch
(cockpit and external switch location),
electrical fire extinguisher system (cockpit
removable steering wheel
FUEL SYSTEM
74L FIA approved bag tank with quick fill
system, 4 internal lift pumps feeding 1
external high presure fuel pump,
braided hoses throughout
PERFORMANCE DATA
Engine installation Transverse, midmounted
Cylinder configuration In-line 4
Capacity 1796 cm3
Bore / Stroke 82.0 mm / 85.0 mm
Valve arrangement 4 per cylinder
Compression ratio 11.5 :1
Fuel tank capacity 74L
Gear ratios
I / II / III Choice of ratios available
IV / V / VI Choice of ratios available
R / Final drive Choice of ratios available
Max Power 213 kW ( 289 PS ) at 7800
min-1
Max Torque 284 Nm ( 29 kgm ) at 6500
min-1
Vehicle mass - unladen¹ 750 Kg
DIMENSIONS
Wheelbase 2300 mm
Track FR: 1457 mm & RR: 1506 mm
Overall length 3877 mm
Overall width (door mirrors excluded)
1727 mm
Overall width (door mirrors included)
1910 mm
Ride Height - midladen² 90 mm
NOTES
1- Unladen: vehicle in running order, no
fuel, no occupant
2- Midladen: vehicle in running order, 1/2
tank fuel, 1 occupant
3 - Provisional specification subject to
change
This post has been promoted to an article
  • Replies 14
AFAIK, no teams have actually said they will race one:
Over 35 Teams have expressed interest in the FIA GT3 European Championship, representing 10 Nationalities, they will
give the new Series its true Pan-European character.
21 TEAMS HAVE CONFIRMED THEIR INTEREST
AF Corse Amato Ferrari Maserati ITALY
Autosport Promotion Jérôme Policand Porsche FRANCE
Autovitesse Michel Duvernay Dodge FRANCE
Barwell Motorsport Mark Lemmer Aston Martin GREAT BRITAIN
BMS Scuderia Italia Marco Streparava Aston Martin ITALY
Callaway Ernst Woehr Corvette GERMANY
Carsport Holland Toine Hezemans Corvette NETHERLANDS
GPC Squadra Corse Batti Pregliasco Ferrari ITALY
JMB Racing Jean-Michel Bouresche Ferrari or Venturi MONACO
Kessel Racing Pier Del Don Ferrari SWITZERLAND
Larbre Competition Jack Leconte Porsche FRANCE
Mach One Racing Serge Masson Ferrari or Viper FRANCE
Monaco Racing Team Gildo Pastor Venturi MONACO
Racing 4 You Ralph Neunteufel Maserati GERMANY
Racing Logistics Hugues Senecal Dodge FRANCE
Rakenta Motorsport Gabor Kassai Not yet confirmed HUNGARY
Reiter Engineering Hans Reiter Lamborghini GERMANY
Riverside Philippe d’Agostino Dodge or Venturi FRANCE
Scuderia Giudici Gianni Giudici Maserati ITALY
SRTS Stanley Dickens Ferrari or Dodge SWEDEN
Tech 9 Motorsport Ltd. Phil Hindley Porsche GREAT BRITAIN
and
The first day of testing for the new FIA GT3 European Championship took place at the impressive Paul Ricard High Tech Test Track. The official GT3 test driver, Christophe Bouchut, spent over four hours trying all the cars which had assembled for the test, in order to start the process of balancing their performance. The cars which had been on display in Monaco the day before were joined by the Nissan 350Z. The fastest time of the day was set by the Aston Martin DBRS9.
Aston Martin DBR9 2:14.669
Dodge Viper 2:14.938
Porsche 997 2:15.765
Maserati Gran Sport 2:18.252
Lamborghini Gallardo 2:18.316
Ascari KZ01 2:19.804
Nissan 350Z 2:21.172
Lotus Exige 2:25.513
I want!!!!.
That gets me back onto the stripes issue again. I know people say they are a bit chav but they look pretty good to me :unsure: .
steve.
Sorry but I didn,t get past the asthetics,I'm just thinking it would look quick parked on my drive regardless of what engine it runs etc.
Lovely innit - Imaging pulling up to work in that bad boy . .
Must admit the stripes caught my eye, and not Chav (but I am biased coz i've got em).. If you look at old Shelby Mustangs/GT40's/Cobras etc they almost always have racing stripes.. To be honest I've never seen a chav round my way with them on a corsa . .
  • 2 weeks later...
I've been told that these times were set in the dry but Gavin Kershaw was close to 3 secs a lap faster than the 'official' time, in the wet!!
