Martin R Posted November 16, 2006 Share Posted November 16, 2006 As its the winter and the little blue bomber is going sprinting next year ive decided on a suspension refresh. Ive bought some Superflex bushes and a set of ball joints. With the fixings etc it should work out at about £400 for the lot. If anyone needs any fixings BTW PM me before you buy and if i have them you can have them at what it cost me. Im also shotblasting the wishbones and replating at the same time as im a fussy so and so at the best of times. Pics to follow when ive cleaned a bit of blood of my knuckles. P.S. Liz is knitting for the impending Grand daughter so we will both be busy this winter Link to comment Share on other sites More sharing options...
Steve J Posted November 17, 2006 Share Posted November 17, 2006 I'd heard not very good reports on the powerflex bushes Martin. Even the current design Nylatron ones are presenting problems (see SELOC thread). Be interesting to see how you get on with the wishbones, as that's something I wouldn't mind doing (was just going to paint them though). Link to comment Share on other sites More sharing options...
Ladders Posted November 17, 2006 Share Posted November 17, 2006 I'll be following this with interest Martin. Think my bushes are completly shot. Where did you get the bushes from Martin? Thought the Poly bushes were meant to be the best to go for! Think I need to do: Bushes TRE's Ball Joints and rear toe links More expense! By the way Martin, I was thinking of painting my wishbones with this POR stuff Linky Let us know how you get on, and take some pic's for us! Link to comment Share on other sites More sharing options...
Martin R Posted November 17, 2006 Author Share Posted November 17, 2006 Dave, these are polyurethane. I discounted the Nylatron due to the problems people are having. It was therefore OE or Polyuretyhane. I decided rightly or wrongly on these http://www.superflex.co.uk/ I will post a few pics later. My decision was based on the fact that the sleeves are Stainless steel and are a bigger diameter than the Eliseparts ones. The bushes are also knurled internally to aid grease retention. We shall see Link to comment Share on other sites More sharing options...
Martin R Posted November 17, 2006 Author Share Posted November 17, 2006 The story so far. Ive taken the front clam off. Ive shotblasted and repainted the front towing eye with Hammerite smooth. The spray can version as though its thinner and needs more coats the finish is spot on. Ive replaced the driving light brackets after a couple of additional coats of Hammerite again. These are a reasonable £8-50 per side Ive removed the front passenger side hub and top wishbone joint. A few pics. Front off Side view Superflex bushes ( 22mm stainless internal sleeve ) The bottom ball joint carrier and steering arm. Ive shotblasted both and yes you have guessed give it the Hammerite treatment. Although where the ball joint and steering arm attaches ive left it just shotblasted. Ive done this by putting a bolt and appropriate sized washer through the hole before spraying. Side view Bottom view You obviously dont want to Hammerite the parts that attach it to the hub carrier as you have to coat these with Duralac ( spelling ? ) to prevent electrolitic ( spelling ? ) reaction. Link to comment Share on other sites More sharing options...
Martin R Posted November 17, 2006 Author Share Posted November 17, 2006 This is turning into a ramble but a couple of other things i forgot i had done. Ive replaced the fixings for the radiator and radiator surround with stainless steel for when the plastic end caps pop as they seem to do on S1,s. They were really rusty and a PITA to remove. I also had a spot of bother with the sill fixings on the front clam and had to saw 3 out of the 4 off ( deep joy ) Ive sourced a supply of 8mm flanged Aluminium rivnuts to replace them with at a very reasonable £3 for ten. From here http://www.nfauto.co.uk/consumables.htm Edit, i also tightened up the jubilee clips on the radiator hoses and 1 was quite loose Anyway back to pics Cleaned up front hub carrier Top view showing steering arm about to be retightened ( if i had the new fixings ) note the shims used to adjust the front wheel camber. Link to comment Share on other sites More sharing options...
Matt C Posted November 17, 2006 Share Posted November 17, 2006 Yum! Looking good! I reckon thats all worth at least 0.5s at Curborough!!! hehe Link to comment Share on other sites More sharing options...
AL G Posted November 17, 2006 Share Posted November 17, 2006 excellent post mate - following this one with interest. I mentioned a while back i was thinking about doing a DIY pre-MOT next spring (I don't have a garage) - am looking at replacing just about everything you have mentioned, TBH hadn't even considered the clam off, am now though - can do my door hinge stays whilst I'm removed... Keep the pic's and story coming Link to comment Share on other sites More sharing options...
Martin R Posted November 17, 2006 Author Share Posted November 17, 2006 Yum! Looking good! I reckon thats all worth at least 0.5s at Curborough!!! hehe Matt, that should only put me about 3 secs behind you then Rear clam in the kitchen indeed. My front clam is in the conservatory along with the bloody cats. excellent post mate - following this one with interest. I mentioned a while back i was thinking about doing a DIY pre-MOT next spring (I don't have a garage) - am looking at replacing just about everything you have mentioned, TBH hadn't even considered the clam off, am now though - can do my door hinge stays whilst I'm removed... Keep the pic's and story coming Alaisdair, glad you reminded me. Under the front clam fixings you have spacers. Well rusty washers, when you get the clam off put them back in the appropriate holes along with the fixings. You wont forget what went where then as this is going to take a while. Link to comment Share on other sites More sharing options...
Daniel Posted November 17, 2006 Share Posted November 17, 2006 I wish I had a bigger garage and actually a mechanical brain to do this stuff. Looks pretty cool. Well done so far Martin. Link to comment Share on other sites More sharing options...
Ladders Posted November 17, 2006 Share Posted November 17, 2006 Martin, how easy is it to take off the rear clam? Have you got a shot blaster at your place then? And more importantly, how many cups of tea does it take to do it in your yellow mug thats pictured? Link to comment Share on other sites More sharing options...
Martin R Posted November 17, 2006 Author Share Posted November 17, 2006 Dave, the reference to the rear clam was at Matt C who appears to be turning his Exige into a rocket ship ready for the new season ( see SELOC thread ) We do have a shotblaster at work We also have a press which saves a lot of messing removing and replacing ball joints. The cup is refilled by Liz in between knitting baby stuff. She has also been unmercifully ribbing me about such a boring thread Link to comment Share on other sites More sharing options...
Rus Posted November 17, 2006 Share Posted November 17, 2006 Are you going to be at donny on sunday Martin? (obviously not on track by the looks of it) I've been thinking about replacing the bushes on my car, nylatron probably a bit over kill so may go for standard rubber ones or the ones you have chosen. Keep us posted on how easy (or PITA) they are to fit. Rus Link to comment Share on other sites More sharing options...
Ladders Posted November 17, 2006 Share Posted November 17, 2006 Rus, if you read the thread on SELOC it will put you off all thoughts of the Nylatrons! Don't know if it's relevant to Elises, but went I went to an Esprit day at Hethel, the suspension engineer was advocating the use of poly bushes over the origonal rubbers. must say something! Link to comment Share on other sites More sharing options...
GCCK Posted November 17, 2006 Share Posted November 17, 2006 You doing the ARB bushes & drop links as well, Martin? Made a big difference on mine. Link to comment Share on other sites More sharing options...
