The new, expanded Lotus Evora GT430 range
  • Evora GT430 Sport joins the line-up
  • Available with both manual and automatic transmission and two body configurations
  • Carbon-fibre and titanium components as standard
  • Variable traction control and adjustable dampers
  • 0-60 mph in 3.6 seconds and 430 hp
  • Fastest ever road-going Lotus - top speed 196 mph (315 km/h)
Lotus Evora GT430 [Blue] (1)
Following the stunning debut of the Lotus Evora GT430, Lotus has introduced an expanded Evora GT430 line-up designed to appeal to a wider range of customers who want the ultimate in high performance sports cars.
Adding to the acclaimed Evora 400 and Evora Sport 410 models, the new Evora GT430 range now includes two body options and a choice of manual or automatic transmission. Joining the recently announced Evora GT430 is the Evora GT430 Sport, a new member of the family that carries the same phenomenal firepower and sculptured body-style but without the additional downforce-creating aerodynamic elements. Both models are powered by the same 3.5-litre V6 supercharged and charge cooled engine, producing 430 hp and 440 Nm of torque (Automatic version: 450 Nm).
Without the aerodynamic elements, the Evora GT430 Sport weighs 10kg less at 1248 kg (dry), bringing the power-to-weight ratio to 345 hp / tonne and the top speed to 196 mph (315 km/h) making it the fastest Lotus production car ever.
Lotus Evora GT430 [Blue] (2)
The Evora GT430 is differentiated from the Evora GT430 Sport through the inclusion of motorsport derived aerodynamics provided by a carbon fibre splitter, a large, profiled carbon wing and louvers on top of each front wheel arch which reduce pressure within the front wheel arches together with wider wheels and tyres.
Automatic transmission will be available from January 2018 for both the Evora GT430 body configurations. With 10 Nm more torque (450 Nm), the Automatic version is even quicker, with a 0-60 mph time of 3.6 seconds. The six-speed automatic transmission utilises an optimised gearbox ECU for ultra-fast changes, whilst gear selection is made via lightweight aluminium paddles mounted to the steering wheel.
Boasting a high specification, the new Evora GT430 range includes, as standard, Öhlins TTX two-way adjustable dampers, J-grooved and ventilated brake discs - paired with AP Racing four-piston calipers all round, a Torsen-type limited slip differential (LSD) and an adjustable traction control system.
Announced last month, the Evora GT430 has already proved a knock-out success. Jean-Marc Gales, CEO, Group Lotus plc said, “The Evora GT430 already has cemented its place as a true collector’s car, but we know that many of our customers want the option of choosing a less aggressive version, with the same power, but without some of more arresting design and aero elements. With the Evora GT430 Sport, we have responded to this demand to add to the whole range of thoroughbred Lotus cars that are great on the track as well as supremely capable on the road.”
Lotus Evora GT430 line-up in more detail
The new Evora GT430 Sport makes full use of carbon fibre to help hit its low kerb weight. This means that standard components include full carbon front and rear bumpers, front access panel, roof panel, rear quarter panels as well as a one-piece louvered tailgate with integrated spoiler.
The whole of the Evora GT430 range also benefits from advanced aerodynamics, including two enlarged carbon fibre front ducts, with integrated air blades, to efficiently move air though to the front wheel cavities and reduce turbulence created by the wheels. The curved rear edges of the front wheel arch panels also play a role, channelling air along the side of the car, while sculpted ducts behind each rear wheel vent airflow as quickly as possible from the wheel arches, balancing downforce. As a result, the Evora GT430 Sport generates up to 100 kg of downforce at 196 mph, some 56% more than the Evora Sport 410. The Evora GT430 generates up to 250 kg of downforce at 190 mph.
Jean-Marc Gales continued, “This is a car that epitomises a purity of engineering that many car manufacturers fail to match. Lotus founder, Colin Chapman not only pursued lightweight design, and pioneered the use carbon fibre in F1, but he also led the way in the field of aerodynamics in road and race cars. The Evora GT430 range continues this legacy, combining our expertise in highly efficient engineering and aerodynamics with more power and torque to provide one of the most rounded and rewarding driving experiences on the road or track.”
Lotus Evora GT430 [Blue] (3)
Once inside, the use of visible-weave, carbon composite components continues. These include Lotus’ beautifully detailed carbon race seats, new carbon door sills and a new lightweight carbon instrument binnacle cover with a new design of graphic on the instrument panel. The steering wheel, dashboard, door panels, transmission tunnel and centre console are all trimmed in a combination of black Alcantara® and perforated leather, complemented by contrast twin colour stitching, in red and white, and matt black interior panels.
Lotus Evora GT430 (13)
An integrated touch-screen infotainment system can be specified, including iPod® connectivity and Bluetooth® functionality, satellite navigation and reversing camera.
Lotus Evora GT430 (10)
The variable traction control function, standard on all models, is linked directly to the ECU and allows the amount of wheel slip to be set by the driver whilst in ‘Race / Off’. The Evora GT430 has 10 mm wider Michelin Pilot Sport Cup 2 tyres with 245/35 R19 at the front and 295/30 R20 at the rear, on one inch wider 10.5J rear wheels – these are optional fit for the Evora GT430 Sport.
Lotus Evora GT430 (9)
Every new Lotus Evora GT430 Sport can be personalised through the increasingly popular Lotus Exclusive programme. Developed by the Lotus Design team to inspire customers, it combines traditional British craftsmanship with the best of modern design, and allows owners to tailor vehicles to their personal taste. Since its introduction last year, roughly a third of all new Lotus cars now undergo some form of customisation.
The new, fully homologated Lotus Evora GT430 range is available in two-seater configuration only and can be ordered now.
User Feedback
  • Jim Clark 60th anniversary celebration of his F1 championship, Indi 500 win & Tasman series championship
    I love the Lotus in the Peak event and it's great to see all the positive posts and pictures of this year's event.  I wasn't there this time because I'd decided to attend the Jim Clark 60th anniversary celebration of his F1 championship, Indi 500 win & Tasman series championship.  This was organised by the Jim Clark Trust and took place at Duns Castle very close to his Scottish home.  It ran on both Saturday and Sunday, so we (six of us) had decided to travel up to Scotland on Friday, have t
    PaulH
    PaulH
    General Talk 2
    Elise S3 Brakes
    Trebor_UK
    Trebor_UK
    Technical Talk 4
    Litp Donation
    Hi Al I just wanted to tell you of Club member Robert Redden's (Trebor_UK ) kind donation to the LitP Rainbows Fund raiser of £100 Just how good is that A BIG thankyou Rob 👏👏👏
    Elisemadray
    Elisemadray
    General Talk
    Formula One
    Maddox
    Maddox
    General Talk 12
    POWER STEERING
    Hi all who car has power assisted steering fitted to their cars. Is it really needed or does it make the driving experience better or worse  Thanks
    Timsrs
    Timsrs
    Technical Talk 4
  • MLOC classifieds
  • MLOC garage
  • Member Statistics
    4,441
    Total Members
    1,800
    Most Online
    martinf
    Newest Member
    martinf
    Joined
