The S2 elise was meant to have all the rear light clusters lit up, but some crappy EU law forced Lotus to disable the inner clusters. I think I understand what your wanting to do,in so much as you want all four rear reds to be lit?? if this is the case it can be done. First off, you need to look at the rear lights from inside the boot,the spare bulb mounting you refer to is probably blanked off,if so it is a real pita to do and in my opininon not worth the trouble. However very early S2's weren't blanked off as Lotus had a few light clusters made as they originally intended and they just removed the bulbs.If your car is the earlier type then you can purchase the bulbs and holders and just plug them into the loom for connection purposes. If its a later S2, first you will have to source the bulb holders and bulbs(not easy),then you'll have to splice into the loom for a feed and then you will have to carefully grind out the blanks in the light cluster to take the holders....
The inner units hold the fog lights but Lotus use a dual filament bulb in there so you need to get a feed to the other filament, which you can take from the outer units, On most S2's when the lights are on it would look like this:
The other half of the inner units are the biggest problem as they are normally blanked off and they need carefully drilling out to accept a suitable bulb holder, if yours aren't blanked off then you just need a bulb holder and again need to get a feed to it, this can be taken from the loom that supplies the outer units.
The bulb holders are notoriously difficult to get hold of, but Nissan and Merc have used them in the past so maybe a trip to thier parts dept armed with one of the Lotus ones as a match might do the trick(Lotus only supply them with the light units and they are £££). Nick Adams the Lotus tecchy guru said that running all the rears from the same loom won't cause any problems as the car was made to run like this from day one. So doing all the above won't overload any wiring/ fuses etc and you should end up with rear lights as in the pic above.
User Feedback
  • Spotted at British Motor Show
    ...does it count if you spot yourself? I joined the SELOC stand at the British Motor Show last week. There were half as many time machines* there as Lotuses! (Well I'm exaggerating actually because there was a Lotus Carlton on another stand and a 340R in the supercar section. Maybe next year I should cross link to the SELOC events page as it would be great to have a bit more of a showing and I know MLOC has some members a bit further south. Enjoyed having a bit of time this aftern
    kayj_prod
    kayj_prod
    General Talk 3
    Toxic Green S-Cup - (Aka Grogu)
    Hi all as with most of my cars I thought I’d start a bit of a build thread. However unlike most cars which I bought and built up to be highly modified the plans for the lotus are quite different and so this will be more thread of its life in my ownership. I have also created a Facebook page called “Toxic Green S-Cup - (Aka Grogu)” containing images of its progress pre and post purchase. Build Page Guide Page 1 * Pre-purchase Photo‘s * First maintenance wash * Trip to Brands Ha
    DC2-CJH
    DC2-CJH
    Garage 40
    Elise S2 111R MFRU multi function relay unit replacement
    Hi Everyone, I need to replace the MFRU on my Elise 111R and I am looking for some advice please. Firstly, can this be done from above, or is it necessary to remove the under tray and do it from below? I am uncertain how much slack are in the connector leads. Also, should the unit simply slide up and off the mounting tab, or is it locked somehow, as mine won't budge. Is there a locking tab that needs to be deflected to unlock the unit. I can't find anything anywhere about thi
    Simon Chapman
    Simon Chapman
    Technical Talk
    Accident Repairers
    Devastatingly I've just had a low speed collision in my Evora - less than 5mph but the front bumper/valance panel is damaged; does anyone know of a decent specialist who can repair/replace the panel - the insurance companies approved repairer will probably be no good - I'm in South Yorkshire  - please help kind regards  Richard
    Richard Bell
    Richard Bell
    General Talk 1
    For sale
    I have for sale a s2 factory short hard top in azure blue . Its currently for sale on ebay if anyone is interested.   Thanks .
    daz-man
    daz-man
    MLOC TV
  • MLOC classifieds
  • MLOC garage
  • Member Statistics
    4,642
    Total Members
    4,445
    Most Online
    Simon Chapman
    Newest Member
    Simon Chapman
    Joined
