Another common problem, the indicator stalk can wear and the main beam may flicker on when you try to indicate. This is a fairly simple DIY fix and very inexpensive. The indicator stalks are a GM part and can be picked up from pretty much anywhere from scrapyards to dealers for a few quid (£10-£15). They are the same as those used on Vauxhall Astras amoungst other things. If you're a bit flush you can get alloy replacements from vendors such as Eliseparts.
To replace the stalk remove the screws holding on the steering wheel column shroud and gently remove it - be careful with the wires that go to the back of the mileometer reset button. With the shroud removed you can simply pull out the indicator stalk and remove the wiring loom from the back of it (its a block connector). Fit your new stalk onto the loom and refit, remember to test before re-fitting the shroud.
User Feedback
  • Spotted at British Motor Show
    ...does it count if you spot yourself? I joined the SELOC stand at the British Motor Show last week. There were half as many time machines* there as Lotuses! (Well I'm exaggerating actually because there was a Lotus Carlton on another stand and a 340R in the supercar section. Maybe next year I should cross link to the SELOC events page as it would be great to have a bit more of a showing and I know MLOC has some members a bit further south. Enjoyed having a bit of time this aftern
    kayj_prod
    kayj_prod
    General Talk 3
    Toxic Green S-Cup - (Aka Grogu)
    Hi all as with most of my cars I thought I’d start a bit of a build thread. However unlike most cars which I bought and built up to be highly modified the plans for the lotus are quite different and so this will be more thread of its life in my ownership. I have also created a Facebook page called “Toxic Green S-Cup - (Aka Grogu)” containing images of its progress pre and post purchase. Build Page Guide Page 1 * Pre-purchase Photo‘s * First maintenance wash * Trip to Brands Ha
    DC2-CJH
    DC2-CJH
    Garage 40
    Elise S2 111R MFRU multi function relay unit replacement
    Hi Everyone, I need to replace the MFRU on my Elise 111R and I am looking for some advice please. Firstly, can this be done from above, or is it necessary to remove the under tray and do it from below? I am uncertain how much slack are in the connector leads. Also, should the unit simply slide up and off the mounting tab, or is it locked somehow, as mine won't budge. Is there a locking tab that needs to be deflected to unlock the unit. I can't find anything anywhere about thi
    Simon Chapman
    Simon Chapman
    Technical Talk
    Accident Repairers
    Devastatingly I've just had a low speed collision in my Evora - less than 5mph but the front bumper/valance panel is damaged; does anyone know of a decent specialist who can repair/replace the panel - the insurance companies approved repairer will probably be no good - I'm in South Yorkshire  - please help kind regards  Richard
    Richard Bell
    Richard Bell
    General Talk 1
    For sale
    I have for sale a s2 factory short hard top in azure blue . Its currently for sale on ebay if anyone is interested.   Thanks .
    daz-man
    daz-man
    MLOC TV
  • MLOC classifieds
  • MLOC garage
  • Member Statistics
    4,642
    Total Members
    4,445
    Most Online
    Simon Chapman
    Newest Member
    Simon Chapman
    Joined
