This should be the same for an S1 as it is for my early S2.
The method I used has been used by others. The current is so small and the wires never move that twist and tape seems to be acceptable. I would have soldered but I'm shit at it and probably would have ruined it rolleyes.gif
OK so here's how I did it:
Remove steering column cowl (2 Phillips and 2 torx screws)
Unbolt stack from underneath (2 x 10mm bolts)
Remove binnacle
Unplug wire to back of Stack. The ones you need to splice into are A2 (black) ,A3 (green) and A4 (white/black). These are the earth, ignition and tacho respectively. The blue clip is numbered so you can actually see which wire is which. This way up a is the top row and wire A1 is on the right hand side.
Strip insulation of said wires (I used a scalpel and still managed to cut through a strand of copper :tsk and wrap corresponding shift-i wire round it. It's quite fiddly as the wires are so close together and fairly tightly bound.
Cover joints in tape and bolt it all back together. Mounted the light at the very back of the binnacle pointing slighty upwards. I can see it over the top of the steering wheel.
Seems to reflex nicely like a HUD on the windscreen too. (y)
Seems to work on on the default sensitivity. One light comes on every 1000 rpm from 1-4000 so far. Didn't go any higher as I was sat in the garage and the engine was a bit cold. Can't for the life of me set up the lower and upper limits though. Didn't seem to work when I did what the manual says. Will have another go tomorrow.
I reckon from start to finish it was about 50 mins. Not bad as I'd never removed the binnacle before and the wires were a bit of a PITA to do as they are so small.
User Feedback
  • Lotus in the Peak Digital info Files
    Please find Digital LitP info below.  Please ensure you are logged into the MLOC forum and then click this link:  Note there Are No Physical Tickets Please print off any of the info contained as you feel necessary. There are:- Map links for the run locations. GPX files. Your final instructions. A full runs group list - please note your group number and leader's name. A copy of the Safety Brief. Important - If you are taking part in a Sunday m
    Elisemadray
    Elisemadray
    General Talk 4
    Lotus in the Peak info
    Hi all that have booked for this years LitP all final info will be emailed out Thurs/Fri please check your spam thanks the LitP team
    Elisemadray
    Elisemadray
    General Talk 4
    Formula One
    Maddox
    Maddox
    General Talk 4
    School prom 21st June help
    Can anyone with an unusual Lotus help me out this Saturday 21st about 6pm in south Derbyshire. So my lad has his school leaving prom this Saturday, some of you will have met Jasper helping out with the parking or sound system at past LITP’s.  As I take Jasper to school in my Evora everyday he doesn’t think it’s special, so I sorted that his friend is going to go in my Evora and I was borrowing my mate Wayne’s S1 Exige to take him as something a bit different .  Unfortunately Wayne’s S1 has
    chris_h
    chris_h
    General Talk 7
    Newbie question
    As the title suggests , a newbie query. I have just bought an S2 Elise , 2007 with the Toyota 1ZZ power unit in ‘ touring spec’. That means electric windows, a radio and , err, not sure what else. Anyway, that is not the subject of the query. The car is blue with a cream interior. The latter I don’t plan to keep. In fact , already bought some equivalent second hand door cards in black and am looking hard at a pair of Corbeau LE seats . So, first part of my query centres on those Corbeau seats. A
    Andy wright
    Andy wright
    General Talk 204
  • MLOC classifieds
  • MLOC garage
  • Member Statistics
    4,439
    Total Members
    1,800
    Most Online
    jimmy_c
    Newest Member
    jimmy_c
    Joined
