  1. Ensure all electrical systems are switched off, including the alarm using the security key.
  2. Lift front bonnet and
    1. Prop up using washer bottle or
    2. Remove front bonnet.
    3. [*] Undo 5 plastic fastners securing radiator sealing fence and remove. (Can be done with this in place if extra care is taken not to crease or damage.)[*] Disconnect pump motor cable and pipes from washer bottle if necessary and secure out of the way.[*] Undo the three 10mm head fixings from the battery clamp and remove.[*] Loosen the 13mm head clamp fixing and disconnect the negative (-)cable from the battery.[*] Loosen the 13mm head clamp fixing and disconnect the positive (+) cable from the battery.[*] Secure all cables to ensure a clear path for battery removal.[*] Lift out battery taking care due to the weight and awkward lifting angle. Beware of handles which may break, or use a lifting tool.[*] Dispose of the battery responsibly at a suitable waste collection or recycling centre.[*] Check and clean battery cables and clamps.[*] Check and clean front chassis earthing point, which can be found by tracing the negative battery cable towards the chassis. Coat with petroleum jelly after reconnection.[*] Lower the new battery into position and reconnect cables, positive (+) first.[*] Coat terminals and exposed cable parts with petroleum jelly.[*] Refit battery clamp and tighten fixings.[*] Refit all other components, close front bonnet, and turn systems back on.
User Feedback
  • Lotus Model Collection
    Lostgear
    Lostgear
    General Talk
    TRD Airbox for Elise
    nick_t
    nick_t
    Technical Talk 13
    Evora 400 Audio Upgrade?
    Jas
    Jas
    Technical Talk 2
    PJT
    PJT
    General Talk 17
    Elise K Series Upgrade
    William D8on
    William D8on
    Technical Talk 68
  • MLOC classifieds
  • MLOC garage
  • Member Statistics
    4,628
    Total Members
    4,445
    Most Online
    zhelinm
    Newest Member
    zhelinm
    Joined
