C1RVY Posted February 4, 2014 Share Posted February 4, 2014 My mate is looking for a 260 cup. Anyone got a good one for sale? Does anyone know the correct factory spec of these cars - do they all have the fuel cut off & extinguishers? The car will be used for racing & sprints & needs to be ready to go, but there appears to be conflicting info out there as to the correct Cup spec. Link to comment Share on other sites More sharing options...
Steve J Posted February 4, 2014 Share Posted February 4, 2014 I think Howard has one of those. Link to comment Share on other sites More sharing options...
chris_h Posted February 4, 2014 Share Posted February 4, 2014 Cup spec could be ordered with or without roll call. When without, the A frame is t45 steel though which enable a full call to be added easily I did two years of sprinting, all he needs to do to a standard car is add the sticker to the ignition and wrap yellow tape around the battery terminal (think also a tie wrap around brake resivoir). As standard the car passes all the other requirements. Still got my carbon and aluminium timing strut, but doubt I'll ever sprint the evora. Link to comment Share on other sites More sharing options...
darryl Posted February 4, 2014 Share Posted February 4, 2014 the standard Cup 260 comes with ignition cut off, fire extinguisher and "A" frame as standard, we had ours removed by the factory as we were doing a lot of touring and euro track days; we got the supplying dealer to relocate the accu-sump unit within the boot area so that we could put two helmets and weekend bags in unfortunately ours was used as part ex for the V6 and is now living somewhere in Scotland, it was at Chatsworth last year Link to comment Share on other sites More sharing options...
C1RVY Posted February 4, 2014 Author Share Posted February 4, 2014 Cheers guys. Did a 240 cup exist as well? How was it any different ( apart from the obvious 20 BHP )? Link to comment Share on other sites More sharing options...
chris_h Posted February 4, 2014 Share Posted February 4, 2014 Yep cup 240 existed when the S was only available as 220. Have a look in our download section as most models are in there. Edit: can't find the 240, here is the 260. http://www.midlandslotus.co.uk/forum/files/download/82-exige-260pdf/ Link to comment Share on other sites More sharing options...
darryl Posted February 4, 2014 Share Posted February 4, 2014 I think the 260 may have had more carbon parts, I think the 240's rear spoiler was part of the boot/engine cover on the 260 you lean over the spoiler to get in the boot or under for that matter; unless you remove the spoiler [4 screws] after doing Spa we needed to change the brake fluid according to the techy at JCT600 we had boiled the fluid light weight battery only held its charge on ours for 4days tops at any one time [we had factory alarm/Immobiliser + tracker fitted] Link to comment Share on other sites More sharing options...
jonnyfox Posted February 4, 2014 Share Posted February 4, 2014 All the info you'll need :-) http://www.hazelnet.org/brochures/ Link to comment Share on other sites More sharing options...
C1RVY Posted February 4, 2014 Author Share Posted February 4, 2014 All the info you'll need :-) http://www.hazelnet.org/brochures/ Spot on cheers. ( info for Tom on Exiges as you probably guessed ) Thanks mate Link to comment Share on other sites More sharing options...
jonnyfox Posted February 4, 2014 Share Posted February 4, 2014 Thought so :-) only found it recently while looking for info on S1's..... Link to comment Share on other sites More sharing options...
