Geek Posted December 26, 2024 Posted December 26, 2024 My Elise s1 111s is currently sorn and stored in the garage connected to a trickle charger, however, I have noticed that the alarm light on the dash is occasionally illuminated. I disable the immobiliser, turn on the ignition and the light extinguishes. But it may be illuminated the next time I check the car. Thoughts on what is causing this? Thank you. Quote
Lithopsian Posted December 26, 2024 Posted December 26, 2024 The alarm on the S1( which alarm?) passively immobilises after 40 (?) seconds. I think the exact time depends on whether the door is open, etc. Then the light starts to flash. You can't stop it without major re-programming (depending on which alarm). Try it. Take the key out, shut the door, and wait. Within a minute, you should see the indicators flash and the LED will come on. It isn't terribly bright, especially after 25 years, and you might have missed it previously. Quote
Solution Badger02 Posted December 26, 2024 Solution Posted December 26, 2024 (edited) 8 hours ago, Geek said: My Elise s1 111s is currently sorn and stored in the garage connected to a trickle charger, however, I have noticed that the alarm light on the dash is occasionally illuminated. I disable the immobiliser, turn on the ignition and the light extinguishes. But it may be illuminated the next time I check the car. Thoughts on what is causing this? Thank you. Sounds normal to me. After removing the key, after a short while the indicators on my S1 flash a few times, even without me pressing the key fob, then the alarm light on the dash starts flashing. Thought all S1 Elise did this Edited December 26, 2024 by Badger02 Quote
Geek Posted December 27, 2024 Author Posted December 27, 2024 4 hours ago, Badger02 said: Sounds normal to me. After removing the key, after a short while the indicators on my S1 flash a few times, even without me pressing the key fob, then the alarm light on the dash starts flashing. Thought all S1 Elise did this It must have always done that and I just haven't noticed. 1 Quote
Geek Posted December 27, 2024 Author Posted December 27, 2024 Thank you for the responses, seems the flashing light is normal and I have just not noticed it previously. 1 Quote
collieek Posted December 28, 2024 Posted December 28, 2024 My alarm light start flashing after a minute or so that is the immob activated. My ind do not flash unless the alarm is activated on the key fob though. Quote
