Virgiltracy Posted July 5, 2022 Share Posted July 5, 2022 Hi guys, are the floor pans different between an s1 and s2? I’ve been offered an S1 set (for my 01S2) but want to see if they fit before I go fetch them. thanks! Link to comment Share on other sites More sharing options...
Daveb99 Posted July 5, 2022 Share Posted July 5, 2022 They are different. I’ve had both… Link to comment Share on other sites More sharing options...
Lithopsian Posted July 5, 2022 Share Posted July 5, 2022 Rubber/plastic floor mats or the carpet mats? The floor pan is the same basic size, but some S2s came with a double-size passenger footrest which needs a special mat size. There is also a version that has no footrest. The S1 always has the single footrest. The S2 carpets have fixings through the carpets - early S1 carpets are velcro'd down while the ones with the chassis corrosion kit are the same as the S2 with the female half of the fixing bonded to the floor. The gear surround is a slightly different shape, but you can work with it. The S2 mats and carpet are what you get if you buy now from Lotus for the S1. So the answer is ... maybe. Depending on which S1 mats they are. Link to comment Share on other sites More sharing options...
Virgiltracy Posted July 6, 2022 Author Share Posted July 6, 2022 8 hours ago, Lithopsian said: Rubber/plastic floor mats or the carpet mats? The floor pan is the same basic size, but some S2s came with a double-size passenger footrest which needs a special mat size. There is also a version that has no footrest. The S1 always has the single footrest. The S2 carpets have fixings through the carpets - early S1 carpets are velcro'd down while the ones with the chassis corrosion kit are the same as the S2 with the female half of the fixing bonded to the floor. The gear surround is a slightly different shape, but you can work with it. The S2 mats and carpet are what you get if you buy now from Lotus for the S1. So the answer is ... maybe. Depending on which S1 mats they are. thanks! My S2 has the double footrest and the mats offered are carpet, I think I’ll pass on them. Link to comment Share on other sites More sharing options...
