Snapper Posted September 18, 2005 Share Posted September 18, 2005 Anyone know where I can get My S2 Exige Noise tested near Birmingham ? I would like to find out how load it is because I have a Stage 2 Sports Exhaust and an ITG induction kit on it. This way I will know what trackdays I could go on and what I can't to avoid disapointment. Link to comment Share on other sites More sharing options...
Stevef Posted September 18, 2005 Share Posted September 18, 2005 Anyone know where I can get My S2 Exige Noise tested near Birmingham ? I would like to find out how load it is because I have a Stage 2 Sports Exhaust and an ITG induction kit on it. This way I will know what trackdays I could go on and what I can't to avoid disapointment. <{POST_SNAPBACK}> when I looked into this I ended up hiring a meter from Book-a-track. cant remeber how much probably 10-15 quid, that including return postage. Only problem is you obviously will struggle with the drive past levels ,unless you get a mate to stand with the meter while you drive past full chat. Steve Link to comment Share on other sites More sharing options...
Fiona Posted September 18, 2005 Share Posted September 18, 2005 Horizon did it for me on Friday. 94db - what a relief. Link to comment Share on other sites More sharing options...
Stevef Posted September 18, 2005 Share Posted September 18, 2005 Horizon did it for me on Friday. 94db - what a relief. <{POST_SNAPBACK}> How did they test it? I assume static at 5k RPM and a couple of meters away side on?. I ask because my S1Exige with sports exhaust was aproblem on track days and I know it was in excess of 98db. I might go to Horizon and get them to check my S2 sounds like a good idea. Cheers Steve Link to comment Share on other sites More sharing options...
Steve J Posted September 18, 2005 Share Posted September 18, 2005 1.5 meters away, at 4.5k revs. Comfortabley under 98dB so not too worried about a couple of dB accuracy. Link to comment Share on other sites More sharing options...
Pesky Posted September 18, 2005 Share Posted September 18, 2005 1.5 meters away, at 4.5k revs. Comfortabley under 98dB so not too worried about a couple of dB accuracy. <{POST_SNAPBACK}> Steve/Fiona You'll be lucky to get away with only 4500rpm at a trackday noise test! Normally it's 75% max revs, & your new beastie revs to 7900! However, most testers don't know the Exige's max revs, & more often than not just ask you to run at 5250rpm (ie they assume a max of 7000rpm). You'll have to be careful going past the driveby meters too (eg Donington), & in future driveby testing will become the norm. I don't remember whether or not your car is de-catted, if it is you would be best refitting it before a trackday, or replacing it with a silenced de-cat pipe (I use one supplied by Eliseparts). The silenced de-cat jobbie, knocks about 4db off. Fingers crossed, & good luck. Link to comment Share on other sites More sharing options...
Steve J Posted September 18, 2005 Share Posted September 18, 2005 Cheers Pesky. It's decatted so will try a quick blast at higher revs when next at Horizon. Llandow is 103dB so should be fine, but Mallory etc will be a problem. Link to comment Share on other sites More sharing options...
Snapper Posted September 18, 2005 Author Share Posted September 18, 2005 You also have to remember that the db level changes in different air temp's. Hot and cold days can change the db level by a couple of db Link to comment Share on other sites More sharing options...
Stevef Posted September 18, 2005 Share Posted September 18, 2005 You also have to remember that the db level changes in different air temp's. Hot and cold days can change the db level by a couple of db <{POST_SNAPBACK}> Along the same lines what is the formula for db doesn't the noise level double for every db at a certain point?. something like that anyway it's certainly not linear. I think we need a boffin Link to comment Share on other sites More sharing options...
malbon Posted September 18, 2005 Share Posted September 18, 2005 just ask someone on exiges who has the same setup - someone must have. afaik the stage 2 struggles to get under 98 - so with an induction kit on id doubt you would be at all - mr g got pulled at donnington cos of his hurricane. as most trackdays are either <98 or the higher level of 105/6 the i think you can just assume that you can't do the <98's but can do the rest ?? Link to comment Share on other sites More sharing options...
Mark A Posted September 18, 2005 Share Posted September 18, 2005 1.5 meters away, at 4.5k revs. Comfortabley under 98dB so not too worried about a couple of dB accuracy. <{POST_SNAPBACK}> As Peskey says the revs are too low, also the meter is too far away, it's usually done at 0.5m, 45degrees. A straight through Cat-pipe will mean the car is too loud for a number of tracks in the UK. Link to comment Share on other sites More sharing options...
Mark H Posted September 18, 2005 Share Posted September 18, 2005 The same car and setup as yours Snapper was too loud for the driveby when I was at Donington. Link to comment Share on other sites More sharing options...
Tango190 Posted September 18, 2005 Share Posted September 18, 2005 I can hire some attractive cans Link to comment Share on other sites More sharing options...
PeterField Posted September 18, 2005 Share Posted September 18, 2005 I was ok on the LoT evening at Donny in August with a de-cat and the Janspeed Supersports? on my S1 exige. Can't have been far off the 98dB limit though! Steve/Fi a reading of 94dB sounds a bit low to me. Link to comment Share on other sites More sharing options...
malbon Posted September 19, 2005 Share Posted September 19, 2005 94 doesn't sound right. Like Peters, mine was probably just under for donny with 4:2:1, Supersports, Hurricane and SILENCED de-cat. With the straight through de-cat that you heard in Le Mans I was told that was near to 110 db !! damn...that was too loud tho !! Link to comment Share on other sites More sharing options...
