Bramble111s Posted August 23, 2005 Share Posted August 23, 2005 Hi all, Was most concerned to find 35.6 litres going into my tank last night, I knew I was a bit low, but crikey, have never even got near 35 litres! Usual is about 27 litres.... Must have been pretty near stopping! Anyone beat that fill up? Link to comment Share on other sites More sharing options...
steve-n Posted August 23, 2005 Share Posted August 23, 2005 usually mine is 31 litres 'ish, the maximum milage per tank was 370 miles. usually 350.00 at between 36 to 38 miles per gallon. Link to comment Share on other sites More sharing options...
MarkW Posted August 23, 2005 Share Posted August 23, 2005 40.5 litres - almost fainted as the car was really running on fumes! M Link to comment Share on other sites More sharing options...
Reg Posted August 23, 2005 Share Posted August 23, 2005 Went to 77 litres in the Esprit a few times (2 x 38 litre tanks) Link to comment Share on other sites More sharing options...
Mark H Posted August 23, 2005 Share Posted August 23, 2005 Probably not a good idea as you will end up sucking all the muck into your filter. Link to comment Share on other sites More sharing options...
Bramble111s Posted August 23, 2005 Author Share Posted August 23, 2005 Certainly not a good idea, hence the horror! 77 litres, Mmmm, that put a dent in your wallet then! 40.5! Impressive! Must've been coasting! yikes, dont think that'll be beaten! Link to comment Share on other sites More sharing options...
Steve J Posted August 23, 2005 Share Posted August 23, 2005 What's more impressive is getting 110 miles to the tank on a run Link to comment Share on other sites More sharing options...
Sonya Posted August 23, 2005 Share Posted August 23, 2005 I thought the standard S1 tank was only 38 litres maximum capacity? Link to comment Share on other sites More sharing options...
Steve J Posted August 23, 2005 Share Posted August 23, 2005 2 litres in the filler pipe possibly? Not much room for fuel expansion if it was that full. Link to comment Share on other sites More sharing options...
Ruxpin Posted August 23, 2005 Share Posted August 23, 2005 I play the fuel game a bit safer in the elise but for the 306 the record is 60.8 litres in a 60 litre tank... edited to say: and being a diesel i'm quite pleased it didn't run out Link to comment Share on other sites More sharing options...
ally Posted August 23, 2005 Share Posted August 23, 2005 On the same vein, has anyone noticed that you only get one warning click from the pump when the tank is full. The next click is usually accompanied by petrol spraying all over you new F?#K*ng suit! ( Just had to get that one off my chest). Or is that just mine? Ally Link to comment Share on other sites More sharing options...
bermudabob Posted August 23, 2005 Share Posted August 23, 2005 I usually get about 2 or 3 clicks.. the last one being a bit tentative though.. Link to comment Share on other sites More sharing options...
Ruxpin Posted August 23, 2005 Share Posted August 23, 2005 Warning click? If i wait for the click i'm normally doused Link to comment Share on other sites More sharing options...
Fozzy Posted August 23, 2005 Share Posted August 23, 2005 I must be doing something wrong then because I'm only getting 230 miles out of a full tank in mine Does having a hurricane induction kit & Sports Zurst have any great impact on MPG?? Link to comment Share on other sites More sharing options...
DunkHSP Posted August 23, 2005 Share Posted August 23, 2005 Yep, 250 miles is probably the most I'll get from mine before I start to panic. As with most cars a long 'steady' run sees me better figures but the short blast to work and back everyday doesn't do much justice to the mpg. Haven't track dayed yet but I should imagine a big drop. (dayed, is that a word?) Link to comment Share on other sites More sharing options...
