GreyKnight Posted June 17, 2005 Share Posted June 17, 2005 Only noticed it a couple of days ago, my steering wheel is very slightly off centre (to the right). I don't remember hitting any pot holes that would have caused this, I'm a bit uncertain how it could have happened. Is it something I could correct, or is it a dealer job? It's not really a problem, but it's annoying... Thanks Graham Link to comment Share on other sites More sharing options...
Jonathan E Posted June 18, 2005 Share Posted June 18, 2005 I had a well known Lotus dealer try to sort mine out 3 times and it still wasn't right,in the end I removed the wheel and moved it on the spline,took a couple of goes but got there in the end,btw this was after a full geo so I safely assumed that everything else was ok,apparently the car S2111s had never been set up correctly at the factory,which is also a common fault Theres alot of info on the brit cars bbs technical section regarding adjustment of track rods etc,search for steering wheel in the archives,seems its a very common problem hth Regards Jon Link to comment Share on other sites More sharing options...
dss123 Posted June 22, 2005 Share Posted June 22, 2005 Gray, It seems strange that this has "just happened". It's not uncommon to get things a little out of line if you have removed your rack for any reason - (new gaters etc) or even new TREs. There are are 2 or 3? splined UJs along the steering wheel shaft and at the steering wheel it's self. I suppose it's possible that anyone of these joints has come loose and slipped or you've knocked something and bent a track rod arm? I would certainly get it all checked out though, cos if something has come loose you need to get it sorted asap! Cheers Dunc Link to comment Share on other sites More sharing options...
Steve J Posted June 22, 2005 Share Posted June 22, 2005 Only noticed it a couple of days ago, my steering wheel is very slightly off centre (to the right). I don't remember hitting any pot holes that would have caused this, I'm a bit uncertain how it could have happened. Is it something I could correct, or is it a dealer job? It's not really a problem, but it's annoying... Thanks Graham <{POST_SNAPBACK}> Surely that's is because your car is "right hand drive" ? Link to comment Share on other sites More sharing options...
