mambosasa Posted April 22, 2005 Share Posted April 22, 2005 When I start the car, I get about a second delay, then it starts turning over slowly, a single cycle at a time, before picking up speed and the engine kicks in. Is this an indication of the brushes going in the starter motor, weak battery or something else? Please advise as I am sure I will end up being stranded somewhere if I don't sort it out soon. Link to comment Share on other sites More sharing options...
Rus Posted April 22, 2005 Share Posted April 22, 2005 Does it do it if you've warmed the engine up, switch off, then start after 5 minutes or so? Link to comment Share on other sites More sharing options...
Martin R Posted April 22, 2005 Share Posted April 22, 2005 Sounds like a battery problem to me. Try fitting jump leads if alls ok then, i would say it must be battery. Link to comment Share on other sites More sharing options...
mambosasa Posted April 22, 2005 Author Share Posted April 22, 2005 Does it do it if you've warmed the engine up, switch off, then start after 5 minutes or so? <{POST_SNAPBACK}> It does tend to get a little better once driven, but still not what you would expect. Could it be a fading alternator? Is there such a thing? Link to comment Share on other sites More sharing options...
Tango190 Posted April 22, 2005 Share Posted April 22, 2005 When I start the car, I get about a second delay, then it starts turning over slowly, a single cycle at a time, before picking up speed and the engine kicks in. Is this an indication of the brushes going in the starter motor, weak battery or something else? Please advise as I am sure I will end up being stranded somewhere if I don't sort it out soon. <{POST_SNAPBACK}> Sure your not driving my TVR, same symptoms when HOT, VERY VERY HOT, fans cut in, all the amperage goes to the fans, forget starting till engine cool. Ask WHOOSHY and the boys, they had to keep push starting me. First time I've heard this on a Liz though. Link to comment Share on other sites More sharing options...
jez_s Posted April 22, 2005 Share Posted April 22, 2005 Sounds like a tired battery! How old is it? also check the battery leads especially the earth connection to chassis. Link to comment Share on other sites More sharing options...
mambosasa Posted April 22, 2005 Author Share Posted April 22, 2005 Sounds like a tired battery! How old is it? also check the battery leads especially the earth connection to chassis. <{POST_SNAPBACK}> My Elise is a 99 model and looks like its still on its original battery. I wonder if I hook up a charger on the battery whilst still on the car would make a difference without blowing up fuses. Link to comment Share on other sites More sharing options...
jez_s Posted April 23, 2005 Share Posted April 23, 2005 Hmm, battery's tend to only last 5 yrs before they start to degrade. You can stick a charger on but i advise taking the leads off first! (negative first of course) Link to comment Share on other sites More sharing options...
mambosasa Posted April 23, 2005 Author Share Posted April 23, 2005 Okay, I hooked up the charger on the battery and it seem to be turning as it should. It looks like I will have to buy a new battery then - bah! Any suggestions on which and where? Link to comment Share on other sites More sharing options...
