MattyB Posted August 16, 2004 Share Posted August 16, 2004 I know this seems like a strange question... But how do you go about making a hole in fibreglass without causing fractures that could possibly spread? Is there a special way of doing it that should be left to the experts?? Don't worry I'm not about to vandalise my Liz Link to comment Share on other sites More sharing options...
Martin_S Posted August 16, 2004 Share Posted August 16, 2004 Not difficult, you can drill using a conventional electric drill. If the hole is bigger than the available drill bits/hole saw, you can chain drill it and clean up the edges of the hole with a file. If you use a hole saw, make sure its a good quality one and that it has a centre drill bit to locate it, otherwise the chances are it will skid off all over the place and scratch the surrounding area. HOWEVER: 1) Always drill from the gelcoated (good) side rather from the reverse side of the panel, otherwise chips of gelcoat will flake of as the drill breaks through. 2) Tape over the area with masking tape first, and drill through the tape - again, this stops the gelcoat from chiping and flaking around the edge of the hole. Link to comment Share on other sites More sharing options...
Mark H Posted August 16, 2004 Share Posted August 16, 2004 Yup have done this to my old one to bolt the headlight covers on, masking tape stopped the drill bit slipping and the paint chipping. Link to comment Share on other sites More sharing options...
Zircon450 Posted August 16, 2004 Share Posted August 16, 2004 Beefy, Any details you have on the headlamp cover "bolts" would be usefull. Mine are gummed on, and full of crap behind them, I saw some VERY small stainless nuts and bolts on an Elise at Brunty, but don't know where to get the little buggers from. Any info old chap ? Link to comment Share on other sites More sharing options...
Mark H Posted August 16, 2004 Share Posted August 16, 2004 The details off the bag of them are: Pan head slotted M33 - 5 x 30MM - 10 PCS Pretty sure I got them from B&Q, they are in a little green bag. Link to comment Share on other sites More sharing options...
Zircon450 Posted August 16, 2004 Share Posted August 16, 2004 Ta Link to comment Share on other sites More sharing options...
Mark H Posted August 16, 2004 Share Posted August 16, 2004 This might also help: http://www.lotus-elise.nl/Mods/Stainless_S...uickoutkit.html The ones I fitted were not as posh as those (i.e. not quick out) had to get my hand behind the wheelarch to tighten and loosen the nut from the bolt but still quicker than removing black goo! Plus they demist a lot quicker. Link to comment Share on other sites More sharing options...
MattyB Posted August 16, 2004 Author Share Posted August 16, 2004 Sounds easy enough... Time to get my drill out! I've bought a DTM/Exige style spoiler off some Max Power site see, needs fixing directly to the bodywork... Link to comment Share on other sites More sharing options...
Mark H Posted August 16, 2004 Share Posted August 16, 2004 Where do you live so I can burn your car first Link to comment Share on other sites More sharing options...
Scott_Mac Posted August 17, 2004 Share Posted August 17, 2004 Can i burn it second? And nick the wheels Link to comment Share on other sites More sharing options...
Zircon450 Posted August 17, 2004 Share Posted August 17, 2004 Ta Ta Beefy That Cloggy's a bit keen with the drill though ! Link to comment Share on other sites More sharing options...
Ladders Posted August 18, 2004 Share Posted August 18, 2004 Matty I'll nick the bit that makes your engine go "Wub wub wub" on tickover Link to comment Share on other sites More sharing options...
Scott_Mac Posted August 18, 2004 Share Posted August 18, 2004 Oi, i'm having those badly timed cams first... Link to comment Share on other sites More sharing options...
Zircon450 Posted August 18, 2004 Share Posted August 18, 2004 Wub wub wub Ladders, you been on the lash again ? WUB WUB WUB indeed ? Link to comment Share on other sites More sharing options...
